How to remove swirls from car with cermic coat?
Hello i have light swirls on my car. The car with cermic coating , how can i remove the swirls from my car without to remove the coating or polish. I need a product that will do this job.
Thanks
Re: How to remove swirls from car with cermic coat?
Originally Posted by
ohad340
Hello i have light swirlls on my car. The car with cermic coating , how can i remove the swirls from my car withot remove the coating or polish.
Thanks
First - since this is your first post to our forum,
Welcome to AutogeekOnline!
Second - I completely understand what you're asking for but I'm sorry to say the product you desire does not exist.
Car Pro Essence Plus sounds like a good candidate for this......it has to be said though, Essence won't necessarily remove the swirls so much as it's going to hide/fill them and not affect the layer of coating now that's IF the defects are in the coating and not the clear coat
Continued....
Here's an article I wrote that explains what it means to remove a scratch or scratches or swirls...
What it means to remove a scratch out of anything...
And while I recommend everyone read the article, here's the jist of it...
In order to remove a scratch out of anything, metal, plastic glass, paint, etc. You must remove material around the scratch until the upper most portions of the surface are level with or equal to the lowest depths of the scratch or defect you're trying to remove.
So in order to remove swirls out of the ceramic paint coating on your car you must abrade and level the surface --> This will remove the coating.
Perhaps it's possible to clean the surface and re-apply the coating and the new addition of the coating will fill in the swirls if they are nano-shallow? I don't know, I don't know if anyone knows. All a person could do is try. (I doubt it would work)
Appears people have had good luck with this on a coated car.
CarPro Essence PLUS 250 ml
Tom
Mr Tommy's
Wash, Buff, Wax
Website: mrtommyshine.com
Questions....
What are you working on?
How did the swirls get into the coating?
I bought the car with this ,
Youe saying there's no product to fill the swirls?
The only product I have heard about is carpro essence plus as Tom said. And as Mike ask you what kind of swirls are they? If they are light wash indused swirls you maybe can save it. Then it's made for carpro coatings in mind also. So with another coating brand it's a long shot that they are working together. If you are gonna polish it carpro glosspad is the pad to use. Test it without polishing first on a small area and see how far it gets you. If it's another brand than carpro I would check that brands top coating and see if it has any filling ability.
How long has the coating been on your car?
Are you meaning that the car has a ceramic clearcoat paint from fabric?
TMQ
Tom.... that's what I meant to suggest was Essence Plus......not Essence, corrected my post.
