Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Super Member Hammer77's Avatar
    Aug 2015
    Adrian, Michigan
    1,043
    Re: Tires/Wheel Cleaners
    A lot of good info here already, here is what I use.
    Tire Brush - Tuff Shine brush.
    Wheel Brushes - Speed Master for the barrels and in between spokes.
    - Mothers wheel brush for the faces.
    Tire/Wheel Cleaner - Megs D143 4:1 with a foaming spray head. To me it uses more product, but it clings very well. Plus D143 is cheap for how much you get.
    Tire Dressing - Gyeon Tire. I love the look and it lasts.
    As Lane said, you may want to look into a wheel coating. I only use wheel cleaner maybe twice a year. I use Pinnacle Black Label (PBL) Wheel Coating, all I use is soap and water. Sometimes I just spray them off with the power washer, and wipe them down with Ech2o at 1:20 and they look mint. Also when you go to clean your tires just spray the cleaner on a wet brush, keeping as much cleaner off your coated wheels.
  2. Thanks azacura, Eldorado2k thanked for this post
    Likes azacura, Eldorado2k, LEDetailing liked this post
  3. #12
    May 2013
    32
    Are you looking into getting large gallons right away or small bottles to start and see if you like them first?
    Small.
    Sent from my SM-G955U using Autogeekonline mobile app
  4. #13
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by Hammer77 View Post
    That’s an interesting tip. Something I’ve never heard before.Tires/Wheel Cleaners
  5. #14
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by azacura View Post
    Small.
    These would be my recommendations.
    Tires: Either of these work well. My personal preference is Tuf Shine
    TUF SHINE Tire Cleaner
    McKee's 37 Tire & Rubber Rejuvenator, heavy duty tire cleaner, how to remove brown from tires
    Tire Brush:
    TUF SHINE Tire Brush
    Tire Dressing: These all work well. If you are in an area that gets a lot of rain then Perl would be the one to not last that long. But it does look great. Gyeon Tire is nice and leaves a matte finish.
    McKee's 37 Gloss Tire Gel penetrates deep below the surface to hydrate and refresh dull, dry rubber.
    https://www.autogeek.net/perl-coat-protectant.html
    https://www.autogeek.net/gyeon-tire.html
    Wheel Cleaner:
    https://www.autogeek.net/dp370.html
    Wheel brushes:
    https://www.autogeek.net/wheel-wooli...ing-tools.html
    https://www.autogeek.net/boars-hair-...ing-brush.html
    I would also recommend coating your wheels to make it easier to clean. McKee's would be the easiest to apply.
    https://www.autogeek.net/wheel-coating.html
    https://www.autogeek.net/gtechniq-c5-wheel-armor.html
    This one is decent thus far.
    https://www.autogeek.net/gyeon-rim.html
  6. Thanks azacura thanked for this post
    Likes azacura liked this post
  7. #15
    Jul 2014
    I have both brushes and woolies, both serve a purpose. Sonax wheel cleaner works best for me and tuff shine tire cleaner and coating. Tuff shine is time consuming at first, but is easily maintained and stays great looking for at least 3 months.
  8. Thanks azacura thanked for this post
  9. #16
    Mar 2011
    PA
    5,792
    Tires I use 3D Yellow degreaser. Very effective.
    Wheels I have coated with Hydro Blue.
    I can just clean them up with soap and water.
    Tire dressing I have been using Gyeon tire. Nice product.
    Brushes I use the Speed master jr. for the barrels. Mothers wheel and tire brushes have served me well.
    2018 Colorado ZR2
  10. #17
    May 2014
    449
    For an “all in one” tire and wheel cleaner, nothing beats Meg’s Hot Rim’s tire & wheel cleaner, IMO. I tried this off the shelf as I was in a hurry cleaning wheels going through my local drive-thru wash. Sprayed all 4 wheels and tires, then proceded to through the brushless wash. Came out and I was shocked how it cleaned them. Wish I took pics of a before and after, it was that good and no brushes used. Highly recommend.
  11. Thanks azacura thanked for this post
  12. #18
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Tire brush the Tuf shine brush
    Tire cleaner McKee's rubber Rejuvinator and Cleaner. I spent my life in the tire business and don't recommend an APC or degreaser for cleaning tires.
    Wheel brushes I have both the speed master and wheel woolies. I like the speed master for heavier cleaner, wheel woolies for maintenance.
    Wheel cleaner McKee's. I've used several including Sonax, Rupes, etc. McKee's performs with the best of them at a lower price.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
  13. Thanks azacura thanked for this post
  14. #19
    Super Member Route246's Avatar
    Mar 2017
    NorCal - San Mateo County
    1,037
    Quote Originally Posted by lane5515 View Post
    I own both the Wheel Woolies & Speed Master brush. I normally use the WW's but the Speed Master comes out for tight areas when cleaning the barrels if needed.
    Tire Cleaner - Shine Supply Wise Guy diluted 1:2.5. I've tried a lot of cleaners and this is the best I've used.
    Tire Brush - Tuf Shine brush
    Tire Dressing - Opti-Bond 1:1.
    Wheel Cleaner - take the time to thoroughly clean your wheels and then coat with GTechniq C5 or DLUX and then cleaning will be a breeze with just soap and water.
    If you don't coat - GG, Sonax Full Effect or McKee's 37 Foaming Wheel Cleaner work good. McKee's 37 wheel cleaner is probably the worst smelling product I've ever used but does a good job cleaning.
    Thanks for this. I've been looking for a good tire cleaner. I'll give it a try.
  15. Thanks azacura thanked for this post
    Likes lane5515, azacura liked this post
  1. Recommend me some tire cleaners that won't brown my tires please!
    Last Post: 10-23-2020, 12:57 AM
  2. Do tire cleaners hurt tires?
    By glen e in forum Auto Detailing 101
    Last Post: 05-01-2019, 02:45 PM
  3. PBL wheel coating safe wheel cleaners?
    By Deebo1133 in forum Pinnacle Wax
    Last Post: 09-12-2014, 08:57 PM
  4. pH Neutral Wheel Cleaners as Tire Cleaners?
    By Setec Astronomy in forum Auto Detailing 101
    Last Post: 05-14-2014, 08:06 AM
  5. Who's using apc as wheel cleaners?
    Last Post: 03-29-2013, 09:01 AM
