Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: DIY vs pay $$$
  1. #21
    Senior Member custmsprty's Avatar
    Apr 2012
    6,471
    Re: DIY vs pay $$$
    You will need both white and orange. Keep this in mind too, heat is the enemy of pads. Heat is generated when polishing and the longer you use the pad the more heat builds up. It will breakdown the pad and reduce the life span of the pad. So buying more pads and switching them out on a regular basis will actually save you money in the long run. A dirty pad also loses it's effectiveness and you can only clean so much build up out of it "on the fly" as they say.
    2015 Hyundai Sonata Limited
    2015 Pearl White Nissan Rogue SL, 2016 Pearl White Nissan Altima SR
  2. Likes PaulMys, Eldorado2k liked this post
  3. #22
    Aug 2012
    142
    Re: DIY vs pay $$$
    I mostly use these pads now as they cut very well and also finish great. Saves me from switching from multiple pads (ie Orange, then white etc etc) Might be something you want to look into.
    Buff and Shine Uro-Fiber Pads
  4. #23
    Apr 2013
    966
    Re: DIY vs pay $$$
    Quote Originally Posted by BudgetPlan1 View Post
    I do have some small bottles of Gyeon Compound and Polish, guess I'll give 'em a try soon. The Gyeon Primer I used last week before coating was an absolute delight to use.
    Curious on your input on these two as well. I like em think “the Guz” likes em, mike Phillips liked them etc. unspoken gems. And the bottle size is good for personal use
  5. #24
    Senior Member BudgetPlan1's Avatar
    Dec 2015
    NE Ohio
    895
    Re: DIY vs pay $$$
    Yeah, been sitting on them since 08/2017. As mentioned, used the Primer last week before giving Gyeon One a whirl. Couldn't believe how little product was needed (2 small drops on pad) and when done, car looked great, almost like it had already been coated. I would imagine the regular polish would have the same level of cut/finish as Primer without the SiO2 benefits. As for the Compound, I think many found it lacking in heavy cutting, hence Gyeons release of Compound+ recently. The small bottles are quite convenient; buying things in 32oz sizes was one of the biggest mistakes I made when starting out.
    Quote Originally Posted by MattPersman View Post
  6. #25
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    4,873
    Re: DIY vs pay $$$
    Quote Originally Posted by jboy2015 View Post
    Hey guys!!
    with detailing season right around the corner for me, I'm on the fence this year to buy my own equipment and do it myself. A pro detail(single step polish and sealant) will cost me about $300 which is about what I'd spend on the following equipment:
    porter cable 7424xp
    three white pads
    clay and lube
    gyeon polish
    gyeon prep
    gyeon cancoat
    ive watched soooo many videos and feel like I'm ready to tackle this, but is a single step polish really as easy as everyone doing the videos says it is?
    or should I take the $200 polishing class at chemical guys first? I really don't want to tho lol
    thanks for reading guys!
    This is a good option. You will like CanCoat and the polish as both are user friendly. The only recommendation I would add is consider having a compound in your arsenal just in case you need something a bit more aggressive. The polish is really nice to work with.
    The number of pads has already been mentioned so you have some good information there if sticking with a one step polish.
    My offer is always there as I mentioned in your looking for detailers thread if you ever need a little hands on or some tips with the products you have chosen, as I have used a majority of them. Then go ahead and let me know.
    I'd stick with your original plan that ends in Gyeon CanCoat, which will not play well with HD Speed. If yer gonna take the time to put a machine on the paint, may as well used dedicated polish and protect with something a bit more durable than HD Speed. Time wise, you'll save about 15 minutes using HD Speed with it's limited Poxy-ish protection vs polishing + Gyeon CanCoat protection. Have never used Gyeon Polish but a small bottle of Jescar Finishing Polish may be a better choice. Not sure the extent of the defects or if a polish will get ya where ya want to be.
    FWIW I started with:
    GG6 DA
    (6) Lake Country Flat Pads - White
    (6) Lake Country Flay Pads - Orange
    Wolfgang Total Swirl Remover 3.0 - 8oz
    Wolfgang Finishing Glaze 3.0 - 8oz
    Poorboys Tornado Pad Cleaner
    Gyeon Prep - 500ml
    12 Pack Edgeless Polishing Cloths
    Unless ya have some deep/more severe defects, the combo will give you medium polish (WG TSR) on orange pads if needed and finishing polish (WG FG) on white pads.
    It's a nice overall combo to start with and you can move on from there if needed....or wanted...or compelled because now your teetering on the edge of the rabbit hole.
    The Wolfgang 'Twins' are pretty close to Menzerna 2400 & 3500 but you can get 'em in the smaller bottles.
    Maybe grab some McKees 914 or Optimun no rinse which you can use in a variety of ways; rinseless wash, waterless wash, clay lube, quick detailer, etc. depending on dilution.
    Everybody has their preferences, this worked well for me when I started. Gyeon CanCoat is a steller way to finish off; great gloss, blindingly easy application, great water behavior and self-cleaning characteristics. Recently read review from user who got a year outta it maintaining only with Gyeon Bathe+, a SiO2 infused auto shampoo which would play nice with CanCoat.
    This is some good advice and I would also stick with the original plan. I agree that CanCoat will give better and longer lasting protection compared to poxy.
    To the op, I have CanCoat on my mom's car going on 7 months and it has held up really well. Maintained with Cure every couple months. I did use bathe+ once and that also worked well with CanCoat. Out of the two I would consider picking up Cure.
    I also used Gyeon Primer Polish as my base which has SiO2 in it which Gyeon claims to add longevity with any of their coatings. The other difference being Polish has a little more cut compared to Primer Polish.
    I have not used the compounds but the polish and primer polish are really nice to work with. Long working time, no dust and easy wipe off.
