Coating, Wax, or Sealant?
Hello everyone!
I need some advice for a balance of maximum gloss and longest protection for paint on a 2016 Dodge Durango Limited with granite crystal clear coat. I have Mckee’s 37 paint coating, Optimum gloss coat, Meguiars Ultimate Liquid Wax, and Meguiars Gold class carnauba paste wax. I will correct the paint before applying any protection. Do paint coatings give more gloss compared to waxes and sealants, when the paint is corrected? I am also looking to do this in the spring time to my daily driver 2005 Chevrolet Impala silverstone metallic clear coat. Any suggestions/advice is greatly appreciated.
Thank you!
Re: Coating, Wax, or Sealant?
A ceramic coating can definitely give higher gloss levels and longer lasting shine, than regular waxes, including those that have polymers in them. However, I found the ceramic gloss more "cold" or synthetic in appearance, than that of traditional waxes with carnauba in them. Ceramic coatings also seem to lack the "depth" effect of some top-level waxes, which can make your clear coat look like if they'd be half an inch thick. This is only obvious in direct sunlight - so, not so much in winter months.
That said I still like ceramic coatings better, because they require far less maintenance, and also offer some level of physical protection, which waxes definitely do not. They are also more chemically resistant. And if you want, you can top off your ceramic coating with a wax coat. This will give you the warmer shine of carnauba waxes, at the price of greatly diminishing the coating's water repelling and self-cleaning properties.
If you're not sure what you want, I suggest you try CarPro's Reload first (in the 100 ml bottle), which is somewhere between true ceramic coatings and waxes. Then you'll see what kind of shine/gloss levels and water repellency you can get with a ceramic coating, but you won't have to prep your paint as thoroughly and won't have to invest serious money. The drawback is that it will only work "at full power" only for a month or so, after which it's gloss and water-repellency will diminish, and be completely gone in 3-6 months time.
Whatever you do, do NOT rely on what manufacturers call their products, because that really means nothing. The terms "wax", "sealant", "coating" are misused a lot of times and to describe very different things, even if they're from the same manufacturer. Prime example being Meguiar's Ultimate Wax, which contains no wax at all, and Gold Class Wax, which does contain carnauba, but also synthetic polymers. Instead look at what the products actually contain and how they work.
Great thank you so much for the info! I’m thinking I will use a coating on both vehicles instead of a wax/sealant for maintenance reasons. Would you say that the self cleaning effect makes up for the slight lack of depth in a coating (compared to a carnauba Wax)?
I will give you MY OPINION: Depends on how you take care of your ride: If it's a DD not garaged and under outside elements, I would do a coating. If you have a garage queen and love to maintain your ride I would go a wax or sealant or both. I love to detail my ride. So I like to wax my ride. On occasion, I will do a sealant topped with a wax. I have tried all 3 and they all have their strengths and weaknesses. IMO you can't go wrong with any of these.
In terms of GLOSS or the wet look, I think and excellent quality wax is the best ON a black car. Again, this is my opinion.
CJ
Save the Manual!
Post Thanks / Like - 1 Thanks, 5 Likes, 0 Dislikes
Both of these vehicles are outside 24/7 365 days a year in northern Michigan’s four seasons. Don’t get me wrong I love detailing my car just as much as anyone on this forum lol. I’m going with the coating from your suggestion because I want the most protection.
I will take this good advice one step further. You also need to consider you climate and lifestyle.
If I lived in Southern California, Florida, or other location with a mild climate AND had time to frequently wax my car, I'd be all over waxes. However, right now life is very busy for me and I live in the Midwest US, so I need something which will survive 6 months of bad weather which doesn't take a lot of upkeep. Initially I went with durable sealants, but have been since moved on to coatings as they are even easier to maintain and go much longer between applications.
Based on your situation I would definitely go with a coating! I live in So Ca and I have a garage queen! In your case coating all the way! Pictures when you are done!
CJ
Save the Manual!
Couldn’t have said it any better!
I will be coating the Durango (Mom’s SUV) sometime this winter with Optimum Gloss Coat. And then in the spring I am going to coat my Impala with McKee’s 37 Paint coating (SiO2 enhanced). Pictures to follow... Stay tuned
As already said, I personally prefer a ceramic coating over a wax, because even though it doesn't look as good to me as some premium waxes do, but it requires far less maintenance, and is more resistant to environmental impacts. And because most people won't notice a difference anyway - because with their untrained eyes they will only register that the car looks "shiny" or "like new"; and possibly even more so with ceramic coatings, which have generally higher gloss levels.
That said it's all a matter of personal preference. Pick the sealant whose appearance you like best, and that fits your lifestyle the best. Meaning, if you enjoy redoing your car on a weekly basis and/or trying out new things and experimenting with stuff, then use waxes, because those will keep you busy. However, if you - like me -, are done experimenting, and just want to be done with the stuff for a while, then go for ceramic, because that's what holds up best, and requires the least maintenance.
With ceramics the only thing you need to do on a regular basis is washing your car properly and regularly (but even that far less frequently, than with waxes) - and whenever you do, you will practically regain the same gloss and shine you had right after you applied it. Other than that, you only need to rejuvenate the coating with a lighter sealant - which can be applied as fast as a spray wax - probably 3-4 times a years, and re-apply the ceramic coating every 2-4 years. That's a LOT less work, than what you'd have to do to maintain the same level of appearance with just regular waxes.
Last Post: 10-19-2020, 09:22 AM
By Cbn in forum Ask your detailing questions!
Last Post: 07-28-2020, 08:20 AM
Last Post: 05-26-2019, 06:16 PM
By Zubair in forum Auto Detailing 101
Last Post: 10-23-2014, 02:26 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 06-03-2013, 06:37 AM
