Page 4 of 4 FirstFirst 1234
Results 31 to 39 of 39
  1. #31
    Senior Member Klasse Act's Avatar
    Feb 2012
    Elk Grove Village Illinois, USA
    14,118
    Re: ONR perfect for MIchigan Winters
    Yeah...me too Kev!
    2013 Abarth-coated 2x's with Wolfgang Uber ceramic paint coating 5-27-17
  2. #32
    Senior Member Legumes's Avatar
    Jun 2013
    237
    Quote Originally Posted by ct18 View Post
    Hoyt do you have streaking issues. I have always used rinseless but for some reason this year i have been battling streaks. I have switched between McKees and Uber. I soak a bunch of MF in solution, i dont do the one mitt method. Last night i did the wifes dark grey car and same thing with the streaks after i dry the car. I take it to the coin op and just rinse it before hand. I still have some D114 left may try that on mine today.
    The D114 should resolve your streaking issues if they're related to product residue and not soiling left behind on the paint. I can leave 1:256 or 1:128 D114 solution on paint and it flashes off cleanly....I wouldn't recommend doing that, but it was just an observation I made in testing. I do rinseless washes indoors, so maybe that makes a difference.
  3. #33
    Senior Member hoyt66's Avatar
    May 2011
    Lake Orion Mi.
    2,034
    Just some food for thought here:
    I would pre-treat each panel before wiping, this way it breaks down the dirt and brings it to the surface and thus reducing the chance of scratching the paint. At the minimum, have a bucket with a grit guard to clean out that mit too. Have you considered doing the Garry Dean method? I would always pre-treat no matter what though, just me. Also, the Work hydroshot makes cleaning those tires/wheels/wells a breeze in the garage!
    Thanks. I used to presoak using a garden sprayer designated for rinseless only. Need to fill that back up, not sure why I got away from it. No good reason that's for sure. I have not tried the gary Dean method. I have watched it and I know it gets solid reviews. I have good results with 2bm (both with grit guard) and a mit. With the Gary Dean method just not a fan of a bucket full of dirty microfibers after the wash process.
    2012 Dodge Challenger RT Classic
  4. #34
    Sep 2017
    Sweden
    299
    When you use Ech2o as a rinseless wash what dilution do you have?
    And if you use a wash mitt do you prefer a chennel mf or a mf mitt? Or is the Garry Dean method the safer way to go with multible mitts and plush mf towels?
  5. #35
    Feb 2012
    14,118
    The GD method is very safe because you always have a clean towel when you need one. Depending on how dirty your car lis you can 1-2 passes per square, so 8-16 swipes per towel. Once done, put it side and grab a fresh towel that's been soaking in the mix. A side note, when doing waterless or rinseless washes you'll have dirty towels afterwards and unless your doing a load of towels right away you may wanna soak them in a separate bucket until you have enough to do a load. Soaking them in some detergent helps break down the dirt in the towels and thus makes cleaning easier when you do that next load of mf towels.
    Also, plush, edgeless towels are the way to go here, no ifs, ands or butts about it. I mean regular mf towels are fine on glass but not for the rest of the car...IMO.
  6. Thanks SWETM thanked for this post
    Likes SWETM liked this post
  7. #36
    Senior Member spazzz's Avatar
    Jan 2014
    Madison
    436
    In winter I use a 1 gallon bleach sprayer with 2 ounces of ONR and warm water to rinse first. I do this twice to really get the wheel wells and undercarriage as much as possible.
    After I see how much sand is sitting on the garage floor I never doubt my approach.
  8. Likes hoyt66 liked this post
  9. #37
    Senior Member kevincwelch's Avatar
    May 2013
    Oak Park, IL (Chicagoland)
    2,574
    I do a method similar to Gary Dean as well. Like Roger, I use all 8 quarters of an 1100 GSM towel. I tend to have it pretty wet, but not dripping with solution. It's probably one of those things where using a very clean mitt with a grit guard is just as safe as using the GD method, but the GD method is what I've adopted and what I use. I totally understand the washing requirements, and it's a bit much sometimes. But, I tend to think of rinseless washes as not "environmental" washes but as a washing method that has less water requirement -- at least on the wash side!
    SWETM: I use 1 oz of ECH2O in 3 gallons. No streaking issues for me.
    Roger also make me up a gallon of ECH2O FrankenDetailer that I have been using as a drying aid of sorts.
    Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
    2013 TESLA MODEL S | Gyeon Mohs + TAC Systems Quartz Max
  10. #38
    Senior Member davidc's Avatar
    May 2007
    Arizona
    1,377
    Quote Originally Posted by luvmyrv View Post
    I have a 31 ft RV that I like to wash after trip, and most times it's dusty but not real dirty, the odd time we get caught in rain and it will have a fair bit of road grime on it. I think I need to switch to trying this on the RV, seems it would be quicker, use a ton less water.
    If you do this I would suggest using the optimum No Rinse Wash and Wax as it has Car Wax in it which helps with UVA and UVB. I use that stuff on everything anymore along with the Car Wax.
    Dave
  11. #39
    May 2011
    Lake Orion Mi.
    2,034
    I use this mit. It does not trap contaminants as easily and rinses out well before putting into my clean media
    https://www.autogeek.net/gold-plush-wash-mitt.html
    I go with 2 buckets and grit guards. One wipe with one side of the mit and the another wipe with the other side. Then dunk in and out of the rinse bucket before dunking in and out of the clean rinseless bucket. This way I am always using a clean mit. For me the key is to having the buckets full enough to get a true "dunking" with your mitt so the contaminants have room to fall. I do need to get back to pre spray though.
  1. What North Dakota winters do to your car
    By lane5515 in forum Auto Detailing 101
    Last Post: 12-30-2016, 10:29 PM
  2. Midwest Winters...salt
    By cleanfreak3 in forum Hot topics & Frequently Asked Questions
    Last Post: 11-20-2015, 04:41 PM
  3. What is better for cold Canadian winters?
    By NiSyam in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-17-2011, 11:37 PM
  4. Detailing in Michigan Winters
    By bcsman in forum Auto Detailing 101
    Last Post: 12-19-2007, 09:14 AM
  5. Longest acting Sealant for Michigan Winters?
    By gilvie in forum Introduce Yourself
    Last Post: 09-10-2007, 04:52 PM
» January 2018
28 29 30 31 123
