» Detailing Classes
Page 56 of 56 FirstFirst ... 64647484950515253545556
Results 551 to 557 of 557
  1. #551
    Senior Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,200
    Re: Sealant comparison
    Quote Originally Posted by Cruzscarwash View Post
    Can you post your latest or your last updated excel of sealants please
    Sent from my Pixel 2 XL using Tapatalk
    Done. The spreadsheet is always available via the link in my sig. (The image upload and management process here drives me crazy.)
    Larger version here.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  2. Thanks oneheadlite, Vegas1, Stacyadams, gorillapr thanked for this post
    Likes PaulMys, tmdals0213, Stacyadams, gorillapr liked this post
  3. #552
    Jan 2016
    Portland, OR
    1,200
    Washed the Rover and Sentra with CarPro Reset using a Big Red Sponge. Wash the Boxster using N-914 and MF towels.
    Collinite 845 and DG 104 are both doing well, of course. They're both clearing water very quickly. With 845 I don't see the water run off - it's just gone immediately. I'm still seeing similar performance from Sonax Spray + Seal. Ultima waterless is also still working after 5 weeks.
    DG 931 as a QD (6:1 ratio) is finally done after 13 weeks. This seems crazy and I'm hoping somebody else will test this as a reality check. McKee's Hydro Blue is also done.
    Rover (video)
    • Red Mist - 8 seconds
    • MS #1 - 7 seconds
    • DG 104 - 1 second
    • Collinite 845 - 1 second
    Sentra (video)
    • Scholl Concepts Barracuda - 10 seconds (almost done)
    • DG 931 as a QD - 14 seconds (calling it done)
    • Ultima Waterless - 3 seconds
    Boxster (video)
    • McKee's Hydro Blue - 12 seconds (calling it done)
    • Sonax Spray and Seal - 1 second
  4. Likes tmdals0213 liked this post
  5. #553
    Jan 2016
    Portland, OR
    1,200
    Added 3 more long term sealants. The weather was not as warm as I expected and I added these late in the day in ~70 degree weather. Hoping they cure well before we get rain. If not, I'll remove and reapply next week. It looks like a few days of 70 degree weather are expected next week. After that I'll likely have to apply products in the garage with a heater.
    These were applied to the driver side front door of the Rover. I polished it with a LC black pad and DG Squeaky Clean, followed by washing twice with CarPro Reset. Here's a video of the water sheeting. About a minute for the door to clear completely.
    Duragloss 111, FK 1000, and Collinite 915 were added.
    Sealant comparison-kz2mc3k-jpg
  6. #554
    Jan 2016
    Portland, OR
    1,200
    All the new long term products on the Rover are doing well. The DG products (104 and 111) are not shedding water as fast as the others. If we get some warmer temps this week I'll get a few more products added. I need to test Soxan Spray + Seal outside on the Rover. It's doing remarkably well on the garaged Boxster.
    Red Mist, MS #1, and Scholl Concepts Barracuda are done. Red Mist looks like another nice Dodo product.
    Rover (video)
    • Red Mist - 12 seconds - calling it done
    • MS #1 - 16 seconds - calling it done
    • DG 104 - 4 seconds
    • DG 111 - 3 seconds
    • Collinite 915 - 1 second
    • FK 1000P - 1 second
    Sentra (video)
    • Scholl Concepts Barracuda - 12 - calling it done
    • Ultima Waterless - 6 seconds
    Boxster (video)
    • Sonax Spray and Seal - 2 seconds
  7. #555
    Jan 2016
    Portland, OR
    1,200
    Washed the Rover and Sentra with CarPro Reset using a Big Red Sponge. Washed the Boxster using CarPro reset using MF towels.
    The DG products (104 and 111) are slowing down faster than expected. For DG 111 the temp may be been too low to cure well. DG 104 had enough heat.
    Ultima Waterless is done. This did amazingly well for a waterless wash. This and DG 931 as a QD are far ahead of anything else I've tested in terms of sheeting water for a QD or Waterless wash. DG gets the vote for cost, Ultima for ease of use.
    DG 104 and DG-111 are slowing down more quickly than I expected. DG 111 may not have had adequate temps to cure.
    Rover (video)
    Collinite 845 - 2 seconds (one small area, most of it is clearing in 1 second)
    DG 104 - 7 seconds
    DG 111 - 10 seconds - this is very surprising. This may not have had adequate temp to cure
    Collinite 915 - 2 seconds
    FK 1000P - 4 seconds
    Sentra (video)
    Ultima Waterless - 12 seconds (calling it done)
    Boxster (video)
  8. Thanks spazzz thanked for this post
    Likes Vegas1, PaulMys liked this post
  9. #556
    Jan 2019
    107
    Was Menzerna Power Lock+ part of the testing? Even though it's not as new as some entries it's still an excellent performer I've found.
  10. #557
    Jan 2016
    Portland, OR
    1,200
    Quote Originally Posted by gofast182 View Post
    I haven't tried Menzerna Power Lock, nor Jescar, which I assume is the same product. I can only buy so many $30+ sealants to use $0.50 worth. I've bought quite a few and traded for many. The ones I buy first are those with sample sizes.
    Edit: Just noticed that Jescar sells samples. Ordered some. May not get get it applied until Spring, but we'll see how Winter goes.
  1. DG QD Comparison?
    By conman1395 in forum Auto Detailing 101
    Last Post: 07-10-2015, 01:33 AM
  2. Comparison
    By omalik93 in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-11-2014, 07:31 AM
  3. Glass sealant comparison
    Last Post: 08-28-2012, 01:29 PM
  4. Sealant/Wax comparison chart
    By CEE DOG in forum Auto Detailing 101
    Last Post: 10-11-2009, 02:03 PM
  5. need a comparison: DP wheel Glaze vs PB wheel sealant
    By Kelso in forum Auto Detailing 101
    Last Post: 12-14-2006, 03:42 PM
Members who have read this thread: 271
» December 2020
2930 1 2 3 4 5
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31 12
