Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Senior Member dcjredline's Avatar
    Mar 2012
    Upstate NY
    2,944
    Re: Is a carnuba really necessary?
    Didnt see anyone say that Carnauba was dead.
    "Dirt likes detergent so much better than the surface that it's attached to, it'll leave that surface to go hang out with the soap"...aim4squirrels
    Member Mathwiz's Avatar
    Aug 2014
    No one made the statement that carnuba is dead. I originally asked the question "Is it necessary to put a carnuba over a sealant (in my case DG105) if the carnuba would create a issue when I decide to reapply the 105 for continued protection. I was asking in the context of bonding issues.
    Actually necessary is not the correct word for me to use. I really should have said "if I use a carnuba over the 105...."
  3. #13
    Senior Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    18,834
    Quote Originally Posted by dcjredline View Post
    Carnauba was dead.
    Quote Originally Posted by Mathwiz View Post
    That's my thinking as well;
    just wanted to make sure.
  4. #14
    Dec 2015
    DG 105 can be topped with anything especially with 601 used. No you might not want to 105 915 105 same day but why would you. The fun part for most on this forum is to use different products to see the result..
  5. #15
    Senior Member BillyJack's Avatar
    Aug 2010
    Western PA
    1,164
    I have and use DG105 and Colli 915 often and see no issues using either one as a topper. 915 over 105/601 was my winter prep on a black DD two winters ago and it lasted well into late spring before I did my spring polishing. DG105 has some cleaner content, so I would expect it would hook up to Colli OK, especially if it's been on long enough that it's starting to wear thin.
    Obviously, conventional wisdom is that we apply the synthetic sealant first, then the carnauba product after, but as Michael Stoops from Meguiars once said about layering, "I've never opened the garage in the morning to find the wax I applied yesterday had fallen to the floor"
    Bill
