Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Senior Member Riff's Avatar
    Dec 2013
    500
    Re: Headlight cracks
    My 2005 Silverado has this problem. It looks like it's all the way through the lens, not just on the surface. I tried some compound and polish on a DA and it didn't help at all. I think I'll be getting new ones.
  2. #22
    Dec 2013
    500
    While we're on the subject. Why don't they make the headlights out of the same plastic as turn signals?-img4072.jpg-img4073.jpg
  3. #23
    Senior Member Calendyr's Avatar
    Jun 2013
    Montreal, Quebec
    2,533
    The best UV protection you can apply is to use a 2K clearcoat. On a Volvo, the headlights are easy to remove so that I what I would do if it was my own car.
    As for headlight vs turn signal plastic, you can be pretty certain it is the same type of plastic. The difference is that the plastic on the turn signal is not submited to high temperature from the halogen light bulb. So the clearcoat doesn't degrade as fast as it does on the headlight side.
  4. #24
    Dec 2013
    500
    Headlight cracks
    Quote Originally Posted by Calendyr View Post
    Idk, on the Silverados, there's daytime running lights if it's in gear so they're on all day.
  5. #25
    Jun 2017
    It has two different reasons. First one, car owner decides to change the bulbs to higher energy ones (commonly thinking to penetrate hazy, yellow headlight lenses) and it cause undesired heat generation. Second reason, it had restored by low quality detailer and (mostly misused rotary polisher builds heat) caused heat shock. These two reasons cracks the headlight mostly to the inside. To detect the cracks prior to restoration, open the headlights (test low and high beams separately) and spray something on lenses (water, soapy water what have you). If there's a crack, it will be visible (illuminated by headlight itself).
    AGOnline kullanarak iPhone aracılığıyla gönderildi
  1. How to get dried wax out of cracks?
    By ihaveacamaro in forum Auto Detailing 101
    Last Post: 08-20-2012, 09:20 AM
  2. possible cracks?
    By Sixbanger in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-02-2011, 04:43 PM
  3. bondo cracks
    By charliehaley in forum Auto Detailing 101
    Last Post: 07-14-2011, 12:30 PM
  4. minimizing cracks
    By vader2 in forum Ask Mike Phillips your detailing questions!
    Last Post: 09-11-2009, 05:20 PM
  5. Cracks and Crevices
    By abrcrombe in forum Auto Detailing 101
    Last Post: 01-31-2007, 05:19 PM
» January 2018
28 29 30 31 123
