Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Oct 2013
    141
    How to clean inside door and jambs
    Hi guys
    What is the best way to clean around the inside of the doors and door jambs?
    Thanks
    Nov 2015
    Los Angeles, California
    13,752
    Re: How to clean inside door and jambs
    I'll add to your question... I'm currently detailing a Hybrid Kia Optima and the door jambs are quite dirty. I've hit the passenger side with APC + steamer but they're not as perfectly clean as I was hoping they'd be... Plus while I was doing that I noticed there's some sort of box which seems to house some sort of electronic device in the door jamb?
    Maybe I'm overthinking it because it's a hybrid but I was a bit hesitant with the steam once I noticed it and normally I'd just say screw it and give the jambs a quik hit with the hose nozzle but I dunno I don't want to mess up anything electric on this car that doesn't even make a sound when it turns on! Lol.
    Has anyone else thought about this? Or am I being overly cautious?
    Super Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,246
    Pros here will have the answer. Obviously wash them as well as you can. I took stronger car wash soap to mine as needed and I used a degreaser in a few spots.Then I went over everything again with a microfiber only or with mild rinseless to get rid of the stronger soaps. They didn't look great until I hit them with some polish and/or paint cleaner. Either by machine with 3" pads or by hand. Once you get them clean and polished it's fairly easy to keep them that way. Most of us apply coating or spray wax (or sealant) after we get them clean.
    Re the electronics, I would wipe it only and not saturate it until you know that doing otherwise is safe (of course).
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
    Sep 2016
    Las Vegas, NV
    201
    If really bad you could hit the area with a foaming degreaser from a spray can and let it set for a few minutes. Then spray it out.
    Waterless wash is working well for me on my maintained cars. Mckee's 37 waterless has excellent lubricity and leaves behind protection as well.
    Nov 2015
    13,752
    The battery's dead on this car now... I hate hybrids. Talk about a buzzkill.
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Super Member David Fermani's Avatar
    Apr 2007
    Metro Detroit
    703
    Pre-soak with an APC, hand wash with a retired wash mitt and rinse.
    Metro Detroit's Leader in Vehicle Preservation & Perfect Paint Finishes
    Jun 2016
    Steamer and MF wipe right behind
    Super Member Mad Wax's Avatar
    Sep 2014
    326
    My process is hit it with a degreaser (foam would work the best), agitate with a brush, rinse off with a hose and repeat if needed. When clean, I air blow dry, spritz on some D156 and hit the rubber boots with a shot of stoners trim shine. Door jambs is one of my least favorite things to do.
  10. #10
    Oct 2013
    141
    When you say rinse, do you mean rinse with water?
  1. How to clean door jambs
    Last Post: 04-13-2016, 07:43 AM
  2. need to clean nasty greased door jambs?
    By 99monguse in forum Tricks, Tips and Techniques
    Last Post: 09-23-2015, 12:34 PM
  3. When to clean door jambs? Interior APC or Exterior ONR?
    By fellipe in forum Auto Detailing 101
    Last Post: 09-02-2014, 09:15 AM
  4. Best way to clean door jambs
    By MurderedC300 in forum Hot topics & Frequently Asked Questions
    Last Post: 06-24-2014, 06:04 AM
  5. How do you guys clean heavily soiled door jambs?
    Last Post: 09-12-2011, 08:43 AM
