Results 1 to 3 of 3
    Super Member kb2ehj's Avatar
    Aug 2009
    Efland, NC
    472
    Duragloss Nu-Glass or Pinnacle GlassWork Water Spot Remover
    Been awhile since I've actually been on the Autogeek forums let alone actually make a post.
    What are people's thoughts on Duragloss Nu-Glass or Pinnacle GlassWork Water Spot Remover?
    I've used the Duragloss Nu-Glass for awhile now (never with a DA always by hand) and have been satisfied with the results but I thought about trying the Pinnacle GlassWork Water Spot Remover just to see if there is any noticeable difference between the two products.
    Sometime this week I might order some more 3" pads to add to the collection to use on the glass, watching one of AG video's I think it was suggested to use the yellow ones' on glass - sound like good advice to you guys?
    As a side note, is Pinnacle GlassCoat Window Sealant with Rain Repellent just re-branded Rain-X or is it really a good sealant/rain repellent?
    Thank you all for the responses.
    Mark
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Re: Duragloss Nu-Glass or Pinnacle GlassWork Water Spot Remover
    Nu-Glass is great for removing light water spotting. For heavier spotting and fine scratches you will need cerium oxide as found in Ceriglass. BTW there is a pad made for glass polishing that is made out of rayon.
    Aug 2015
    263
    Haven't used Pinnacle but have had great success using Nu Glass with a cutting pad or a glass polishing pad on my DA polisher. Takes out the spots and leaves a nice surface. I'll typically follow up with Panel Wipe or IPA to get the surface squeaky clean before applying a glass coating/sealant.
  1. Replies: 15
    Last Post: 05-26-2015, 10:34 AM
  2. Pinnacle GlassWork Water Spot Remover
    Last Post: 02-06-2014, 05:49 PM
  3. Just tried Pinnacle Glasswork Water Spot Remover
    By Skoob in forum Auto Detailing 101
    Last Post: 01-22-2014, 10:43 AM
  4. How to Polish Glass with Pinnacle GlassWork Water Spot Remover
    Last Post: 05-20-2013, 01:27 PM
