Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Junior Member BMack's Avatar
    May 2017
    47
    Surface Prep For Paint Coating - How Perfect?
    I'm working on my final polish before applying Gyeon Mohs coating to a black Dodge Challenger.
    No matter what I do, however, there's always a little dust and lint left on the paint after I wipe it down with GTechniq Panel wipe and two Gyeon MF Towels. One to wipe and the other to buff. The surface looks perfect under normal lighting, but the dust and lint are very evident when I put a spot light on it. I've pre-washed the towels and go over them with a lint roller before using. I've also tried the Gyeon Prep as is recommended, but it doesn't seem to work very well. I've used some other MF towels, cheap to expensive, but they leave an incredible amount of lint behind.
    Will this minimal amount of dust and lint be an issue or is this normal before such paint coatings? I assume it will get embedded in the coating for however long it lasts.
    Appreciate any info.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,093
    Re: Surface Prep For Paint Coating - How Perfect?
    Have you tried a final wipe with a suede towel?
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    Edit: misread your post.
    A suede towel or a towel meant for glass would be a great final wipe for you.
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
    May 2017
    47
    No, I didn't think of that, but I see the CarPro MF suede towels in the store. I think I'll try it out. As the coating is applied with a small suede cloth makes sense to wipe it before and after with the same.
    May 2017
    47
    Yes, I've pre-washed and gone over them front and back with a lint roller.
    Aug 2013
    St Louis metro (Illinois)
    5,795
    My garage is a little dusty, so I keep a clean MF towel handy when applying the coating. Right before I apply the coating, I go over the area one last time VERY gently to remove any dust that might have landed after I did my prep wipe down.
    Super Member PouncingPanzer's Avatar
    May 2017
    Cleveland
    901
    I wipe with Eraser and then right before I lay the coating I take my master blaster to the car and dust it once more.
    2019 GLI 35th Edition DSG in Pure Grey w/ OEM+ IS38 turbocharger and various bolt-ons.
    May 2017
    47
    Great info, thanks so much. I'll be trying suede towels, working in small areas and blowing the dust away. Don't have a Master Blaster but an air compressor should do the job.
    To answer your question...
    More perfect is more better
    Here's my go-to towels,
    Meguiars Professional Ultimate Wipe® Detailing Cloth - 16 x16 Normally $5.99 on sale at the time I'm making this reply for $4.99
    GYEON Bald Wipe Microfiber Towel 16x16 $6.99 each
    Both of these towels use a flat weave style. No individual fibers, either open or looped.
    Get a dozen, wash them first. Wash immediately after use. Store in a clean place. Dedicated for use with coatings.
  10. #10
    May 2017
    Cleveland
    901
    98% perfection is always my goal. So as perfect as possible.
  1. Review: PBL Paint Coating & Surface Coating - IFINITI QX30 in Magnetic Red
    Last Post: 10-12-2020, 01:59 PM
  2. Pinnacle Paint Coating.. Is surface prep really needed?
    By Billy Baldone in forum Auto Detailing 101
    Last Post: 07-05-2019, 07:56 PM
  3. Replies: 0
    Last Post: 10-08-2016, 10:18 PM
  4. Difference in PBL Surface coating and Paint Coating?
    By Marc Hufnagel in forum Pinnacle Wax
    Last Post: 02-20-2014, 08:23 PM
  5. Replies: 2
    Last Post: 11-08-2013, 04:09 PM
