Page 2 of 26 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 255
    Nov 2009
    Pasadena, CA
    11,856
    Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.
    Quote Originally Posted by idriveblackcars View Post
    So do you think the Mille can finish better than my 15mkII? My paint never gets hammered so how a machine finishes is my main concern.
    Also I'm assuming more pads from Rupes?
    I think it depends on the paint hardness. Harder paint, the forced rotation will finish just fine. Softer, a free spinning DA for sure. I'm not sure how effective the free spin mode will be for the Makita. I'm buying it for the forced rotation, so if the free spinning mode doesn't bog down easily, that will be icing on the cake
    '03 Corvette Z06
    Nov 2009
    Pasadena, CA
    11,856
    Re: Flex 3401 vs. Rupes Mille/Makita P5000C, for those that are wondering.
    Quote Originally Posted by Philips146 View Post
    Where did you find that info?
    Posted directly from Rupes on FB.
    '03 Corvette Z06
  3. #13
    Apr 2015
    PGH, PA
    1,171
    Mille
    clockwise
    5.2mm Stroke
    7,490 OPM
    14 orbits per rotation at 535 RPM
    900 watts
    motor amps ???
    6.17lbs
    PO5000C
    Clockwise
    5.5mm stroke
    6800 OPM
    Math comes out to 8.608 orbits per 790 rpm
    900 watts
    7.8 amp
    6.2lbs
    3401
    counter clockwise
    8mm stroke
    4800 OPM
    10 orbits at 480 RPM
    900 watts
    9amp
    5.73lbs
    Mike Phillips may you spin backing plate and count how many orbits per rotation on the PO5000c?
  4. #14
    Member Philips146's Avatar
    Aug 2016
    Kailua-kona HI
    63
    If the price is not too high then looks like I'll be getting a mille to compliment my 21 MKII.
  5. #15
    Nov 2009
    Pasadena, CA
    11,856
    The 3401 spins at 4800 OPM, not the claimed 9600. Kevin Brown tested and proven.
    '03 Corvette Z06
  6. #16
    Sep 2014
    PA
    643
    looking forward to some reviews of these polishers,
    one would think it was SEMA with all these releases! Always something happening in the detailing industry!
  7. #17
    Senior Member VISITOR's Avatar
    May 2007
    7,663
    as mentioned.. a test side by side is going to be the true test even with all the stats. it should be interesting...
  8. #18
    Apr 2015
    PGH, PA
    1,171
    as did Tom Helme
    anyone with a 3401 on hand can do same
  9. #19
    Nov 2009
    Pasadena, CA
    11,856
    Quote Originally Posted by nothingface5384 View Post
    Mille
    clockwise
    5.2mm Stroke
    7,490 OPM
    900 watts
    motor amps ???
    6.17lbs
    PO5000C
    Clockwise
    5.5mm stroke
    6800 OPM
    900 watts
    7.8 amp
    6.2lbs
    So, on paper, which should have more cutting power?
    '03 Corvette Z06
  10. #20
    Apr 2015
    PGH, PA
    1,171
    id like to say the Mille, but i'm sure it'll be very negligible between Rupes and Makita
  1. Rupes UHS with the flex 3401?
    By seanosborn in forum Flex Polishers
    Last Post: 08-08-2015, 12:22 PM
  2. Rupes vs Flex 3401 VRG vs GG6 with MF
    By Krisek in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 04-04-2015, 09:31 AM
  3. Comparison of Flex, PC, DeWalt, Makita, Rupes
    By clnimck in forum Flex Polishers
    Last Post: 11-26-2014, 04:13 PM
  4. Flex 3401 or Rupes 21?
    By Gsrjake in forum Auto Detailing 101
    Last Post: 10-04-2013, 06:27 PM
  5. which one to choose makita bo6040 or Flex 3401??
    By style in forum Ask Mike Phillips your detailing questions!
    Last Post: 12-04-2012, 11:44 PM
