Results 1 to 7 of 7
    Jul 2016
    3,328
    Is it possible to strike threw the clear coat with a finish pad and finish polish?
    Is it even possible to strike threw the clear coat with a finish pad and finish polish? I'm still fairly new to detailing and still trying to get my bearings on everything.
    Super Member Cosmin's Avatar
    Oct 2009
    Austin TX
    742
    Re: Is it possible to strike threw the clear coat with a finish pad and finish polish?
    Quote Originally Posted by fightnews View Post
    it all depends how thin the paint is , best sign is to inspect the paint and see if was abused before ( residue of compound, heavy holograms from rotary, improper finish on repaint panels, damage trims or with compound of them, vents-grills with residue)
    also edges can be thinner than the rest of the panel.
    let the paint talk with you
    Detail Luxury and Exotics in Austin area
    @proreflection
    www.proreflection.com
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    Rotary or Dual Action machine?
    Rick....now in North Texas
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Uh-huh.
    In fact: the horror stories,
    of doing so, abound!
    Super Member david b's Avatar
    Jan 2015
    344
    Threw or through?
    Jul 2015
    145
    Stay off the edges
    Sent from my XT1585 using Tapatalk
    Jun 2013
    Montreal, Quebec
    3,996
    Considering that polishing with a DA using a polishing pad and 205 will remove at most 3 microns, the paint would have to be at failure point already if you can strike through it using a finishing pad and finishing polish that will probably remove at most 1 micron. There is also a danger on edges but again, DAs are very safe especially with the pad and product you are using. So the quick answer is no. Of course anyone trying to do damage can probably find a way, but if you are careful about edges and not leaving the DA at high speed on the same spot for ridiculous amount of time, I don't how you could cause damage with that combination. Before polishing or compounding it's always best to measure paint thickness if you can. As a rule, polishes remove very little paint, so I consider them safe for almost all paint.
  1. Whats the hardest finish to protect soft clear coat
    By chrislorl in forum Auto Detailing 101
    Last Post: 12-04-2013, 04:18 PM
  2. Menz SF4500 /Optimum Finish Polish/WG Finish GLaze
    By primo spaghetti in forum Ask your detailing questions!
    Last Post: 11-03-2012, 03:25 PM
  3. removing spray wax spots on clear coat finish
    By msakowski in forum Auto Detailing 101
    Last Post: 02-22-2012, 05:19 PM
  4. will wolfgang paintwork polish hurt a clear coat finish?
    By samhwheel in forum Auto Detailing 101
    Last Post: 06-14-2011, 10:31 PM
  5. Clear coat finish worn off
    By cobra29 in forum Ask your detailing questions!
    Last Post: 06-06-2011, 06:57 PM
