Results 1 to 6 of 6
    Oct 2015
    Ohio
    78 camero with single stage metallic paint
    Ok so I did the maguires no.7 polish rub down. I first left it on for 2 hours then whipped down and reapplied. I ended up leaving polish on car for 2 days. When I wiped it off I used a clean dry terry cloth and now I have one section that is not right. Any help or advice would be greatly appreciated ATTACH]56170[/ATTACH]78 camero with single stage metallic paint-1491072146508-jpg78 camero with single stage metallic paint-1491072157577-jpg78 camero with single stage metallic paint-1491072170436-jpg
    Sent from my LG-H810 using Autogeekonline mobile app
    Attached Thumbnails Attached Thumbnails 78 camero with single stage metallic paint-1491072130538-jpg
    May 2011
    1,205
    Re: 78 camero with single stage metallic paint
    Why.... After 50 years can no one spell CamAro correctly?
    Jun 2014
    Chandler, AZ
    3,360
    Hi, welcome to AGO.
    First off, it's very difficult to see your photo's. You can upload your photo's to the free / unlimited web gallery and repost the pics.
    https://www.autogeekonline.net/forum...r-message.html
    The #7 rubdown is typically to gorge old dried out paint with the oils found in #7 (a non abrasive polish). Typically done when single stage paint is neglected and very oxidized. If the paint wasn't in bad shape to begin with, it probably didn't require it.
    The #7 Rub Down Technique by Mike Phillips
    Do you mean the #7 or another polish?
    It's quite possible after two days it has become dry. Just wiping with a terry cloth will be difficult and or possibly not get it all off (by hand).
    You could try a rinsless or waterless wash to wipe off any excess polish and polishing oils.
    That is where I would start before trying anything more aggressive.
    May 2011
    1,205
    Can you get better pics? They are not very telling of your problem.
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Keep in mind:
    Correcting/Buffing SS Metallic
    changes the flake and depth; i.e.:
    creation of "the tiger stripes fx"
    is very likely---Not pretty.
    Oct 2015
    Ohio
    Yes no. 7. The paint was def in need of something! I did a walk around inspection and didn't notice any thin spots. It all looked even. I did notice that it must have been repainted because it's had some body work to same side that I'm having the issue. I will re-download better pics in just a sec. Thx guys!
  1. Scuff & Buff - Wet Sanding Single Stage Metallic Paint - 1948 Willys Jeepster
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 10-15-2018, 07:55 AM
  2. Replies: 6
    Last Post: 06-27-2017, 07:32 AM
  3. Detailing a vehicle with 40 year old single stage enamel metallic paint
    By pclancy in forum Autogeek's DetailFest Info
    Last Post: 01-12-2017, 10:01 PM
  4. 68 Firebird Single Stage Metallic Paint Restoration
    By ryanfelix in forum Ask your detailing questions!
    Last Post: 08-15-2016, 01:07 PM
  5. Single Stage Metallic & Clearcoat Metallic --> Same Car
    Last Post: 07-22-2014, 05:08 PM
