Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Aug 2013
    St. Louis, MO
    580
    Re: Issues with Rupes mk2 - 15mm and buffer trail
    Quote Originally Posted by coolcobramatt View Post
    The Rupes and AG reps I've spoken with all know of the melting pads (melts the black velcro to the backing plate), it's just a result of the excessive heat that the Mark II's can build up in the center of the pad. It looks like the pad is caving in and you can only tell when the pad starts throwing pieces of foam all over the car as it disintegrates. If you haven't witnessed it yet then consider yourself lucky. Literally forced me to sell a near new unit.
    I believe you - I've seen a couple posts on here showing that. I am just surprised to hear you sold the machine. I have never run mine above a 4 so I think I'm mitigating some of the heat buildup because of the low speeds.
    Aug 2011
    The "OC"
    895
    Pads melt or fail because of:
    1. Using 1-2 pads for entire car. Should be using a minimum of 4. I use 6 or more sometimes.
    2. Over saturated pad. Pad gets heavy and grabby and more likely to discenerate.
    3. Speed on polisher is too high. Speed 5-6 on a Rupes held in one spot too long will cause pads to fail.
    Melting backing plate:
    1. Polishing non stop will heat up the the tool....like trying to compound an entire car without take breaks to wipe off the panel.
    2. Extension cords that are to thin or too long. Use the correct gauge. You don't want to be using 50ft of 18awg Christmas light extension cord. The resistance is too high. The tool heats up, heat travels down the spindle and melts the backing plate.
    There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
  1. Rupes 15mm MK II vs. Chinese 15mm...my thoughts
    By WRAPT C5Z06 in forum Product Reviews
    Last Post: 02-13-2019, 09:33 AM
  2. Isolated buffing marks / buffer trail
    By Jmbrown415 in forum Auto Detailing 101
    Last Post: 04-03-2017, 11:17 AM
  3. Hologram/buffer trail help
    By Rtrick87 in forum Auto Detailing 101
    Last Post: 08-02-2016, 02:10 PM
  4. Rupes 15mm or 21mm
    By Joelotto in forum Auto Detailing 101
    Last Post: 03-27-2013, 11:52 AM
  5. Buffer Trail Holograms
    By WannabeG in forum Auto Detailing 101
    Last Post: 06-02-2011, 01:09 PM
» October 2023
1 2 3 4 5 6 7
8 9 10 11 12 13 14
15 16 17 18 19 20 21
22 23 24 25 26 27 28
29 30 31 1234
