Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    Nov 2016
    Rust forming on 2012 Nissan Altima 2.5 SL. Can this be stopped?
    Hey All,
    So I am getting very interested in detailing my car from lurking on this website and forum for a few weeks. I recently spent some time thoroughly inspecting my car just to see what I was dealing with as far as paint correction and noticed this small rust spot on the rear bumper. It looks like there is a small chip right where the body of the car meets the metal trim by the license plate.
    Some pics: Rust forming on bumper - 2012 Nissan Altima 2.5 SL - Album on Imgur
    Close up of chip: Imgur: The most awesome images on the Internet
    Any idea on how I can mitigate/stop this? I bought some Iron X and I've read a little about Rust Converters like Corroseal. I asked another forum this question and was basically told to clean paint the area.
    I am hoping that this is so small I could take care of it on my own. Thank you in advance for any help!
    Super Member natewood70's Avatar
    Dec 2010
    Royal Palm Beach, FL
    610
    Re: Rust forming on 2012 Nissan Altima 2.5 SL. Can this be stopped?
    Welcome to AGO!
    Since that seems so tiny at this point, I would clean out the chip that is there really well to remove any of the surface rust to expose the bare metal.
    From there, I would add some touch up paint to fill it so that it will stop from potentially spreading. Seems to be in a corner so if you want to minimize marring or impacting the surrounding area while you clean (you may need a stiff brush), I would tape off the surrounding area with painters tape to be safe.
    A year from now, you'll wish you started today.
    @utopiandetailing on Instagram.
    Aug 2010
    New Jersey
    15,158
    As Nate stated, you need to clean that to bare metal, and put some touchup paint on there. Just keep in mind it won't look perfect but at least it won't be rusting anymore. And yes, you'll want to tape off close to that so you don't damage any good paint.
    You'll want to scrape the rust with the corner of a razor blade, or with a "sanding pen". They used to sell those pens at Griot's but I don't see them anymore. These applicators are good:
    Griots Garage Touch-Up Paint Applicators, 25 Count
    Griots Garage Fine Tip Touch-Up Paint Applicators, 25 Count
    You can also find those in bulk, as well, as the sanding pen, elsewhere on the internet. When you get your paint, you may want to consider some primer if there are deep pits...just make sure to apply the primer really thin, you want to leave room for the paint without leaving too much of a blob. Honestly, when I touch up rusty chips I don't usually use primer, but, again, it depends how deep you have to go to clean that up. Also consider getting some thinner when you order the paint, sometimes it's just too thick out of the bottle (or may become that way the next time you go to use it, although the last little bottle of thinner I got came in a plastic bottle and seemed to permeate through the bottle and is almost gone even though I haven't used any of it).
    And remember...thin is in...in regard to how much paint you are putting down. Make sure to wipe the area with some IPA after you're done scraping.
    Super Member WaxMaster1's Avatar
    Jul 2015
    Central Florida
    1,261
    It looks to me as if one of the panels was repainted because the paint doesn't appear to be uniform in color. So, who knows what's going on, but I would just scuff up, clean out the area and lay some touch up paint down. From the looks of your name, seems like you're in a snowy area so I'd monitor it closely this winter and maybe touch up again in the spring if necessary.
    Nov 2016
    Thanks everyone for replying and thanks for the welcome Nate!
    I plan on taping off the area, using a sanding pen to scrape away the existing rust and then depending on the severity of the pitting, go over it with touch up paint or primer & paint. When using the sanding pen, should I wet the surface like in wet sanding or is that not necessary? Would it be beneficial to use a Rust Converter? I've read a little about them, but not sure if this is the best application for that product.
    Thanks again for all the help!
    Dec 2010
    610
    I don't think a rust converter is necessary for something that small. As long as you can clean the area of any residual rust to bare metal, following with touch-up should be fine.
    Nov 2016
    Awesome, thanks for the tips. I'll post some before and after pics once its done. It's a minor correction, but I have never done anything like this before. Hope it all goes well!
    One more question, should I try and get paint from the dealer or pick something up from my local auto parts store?
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    I can't see the pictures for some reason. I used a dremel to clean out some small...and some not so small rust spots on a '72 VW. You actually remove a little metal, but with rust if you don't remove it all it's going to come back quickly. I tried a rust converter but in the real small spots it proved to be pretty worthless. It may just have been that particular product though...
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
    Nov 2016
    Rust forming on 2012 Nissan Altima 2.5 SL. Can this be stopped?-20161120_134004-2-jpg
    Let me know if you can view this one. This is a close up of the spot.
  10. #10
    Dec 2010
    610
    Quote Originally Posted by Chicagoil135 View Post
    I would usually go to the dealer unless the price is astronomical. You can get stuff from auto parts store with the same color code, but it will sometimes be slightly off shade. Won't really be noticeable in that spot, but might as well get the best match possible IMO.
  1. Rust forming
    By Nav45 in forum Auto Detailing 101
    Last Post: 07-21-2016, 06:21 AM
  2. 2005 Nissan Altima
    By David Hayward in forum Show N' Shine
    Last Post: 09-03-2014, 11:44 PM
  3. 06 Altima lots of rust
    By EddieF in forum Off-Topic
    Last Post: 08-21-2014, 10:17 PM
  4. AIO on Nissan Altima
    By HateSwirls in forum Show N' Shine
    Last Post: 04-19-2014, 10:03 PM
  5. 2005 nissan altima
    By mandodgeshane in forum Show N' Shine
    Last Post: 12-24-2013, 12:23 AM
