» Detailing Classes
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Senior Member The Guz's Avatar
    Jun 2013
    Lawndale, CA
    6,589
    2016 CarPro SEMA Products
    For you CarPro fans. Images and information courtesy of detailed image.
    We got to see two new products from CarPro today at SEMA, the Essence Plus and EcH2o. Ech2o is a concentrated waterless wash that can be used in various different ways on various different surfaces. The Essence Plus, sounds like an enhanced version of the already popular . We do not have much information on this new product, but we are intrigued to say the least! Also included in this post are new 2″ pads, the 2Face Microfiber Towels and upgraded 1L bottles across the CarPro product line. When we get these up on the site we will be sure to make an announcement asap. What do you guys think of these products!?
    CarPro EcH2o Concentrate: Waterless Wash & High Gloss Detail Spray
    EcH2o is an entirely new waterless cleanser and gloss-enhancer built on 2 years of research and development by CarPro Chemicals! EcH2o was designed to work in harmony with ceramic coatings and even provides easy cleaning of non-coated or waxed surfaces! Based on a SiO2 hybrid framework and an eco-friendly organic lubricant solution, EcH2o safely cleans and glosses a variety of exterior vehicle surfaces with ease! Paint and chrome take on an entirely new level of gloss and reflection with this incredible formula and better yet it is easy to use even in extreme heat and direct sun on painted surfaces! Our solution to providing a swirl free and eco friendly waterless experience is a blend of proprietary lifting agents combined with natural organic extracts and lubricants. The secret to the safe cleansing abilities provided by EcH2o is a combination of its modified high gloss SiO2 component and its innate cleansing abilities, which easily removes dust and light dirt whilst leaving behind a wet, glass-like surface! The finish left by EcH2o mimics the incredible properties that have become synonymous with CarPro SiO2 sealants and CQuartz coatings throughout the years! In conjunction with a quality microfiber towel, the lubricants aid in safely removing the larger particles from the surface while the remnants of the EcH2o solution become an active cleaner across the surface and begin to loosen any particulates that were left behind. Before the final step (noted in the product directions) the solution may dry to a fine haze indicating it is ready to wipe off any remaining product effortlessly!
    As Quick Detailer:
    • Shake well and dilute 1:10~1:20
    • Spray, spread, and wipe off completely
    As Waterless Wash:
    • Shake well and dilute 1:5 up to 1:10
    • Spray liberally across one entire panel
    • Lightly wipe with CarPro BOA towel flipping towel to fresh sides often
    • Spray once more across panel surface
    • Using a fresh BOA towel wipe surface removing remainder of dust and dirt
    • Move to next panel, repeat steps 2-5, and continue around vehicle
    • Final wipe entire vehicle with a fresh clean towel as needed
    Precautions:
    • Test product on inconspicuous area before use
    • Store in cool dry place
    • Keep away from children
    • Do not ingest
    CarPro Essence Plus: Top Coat Jeweling Agent
    Imagination becomes reality… Introducing an incredible new tool for detailers around the world! Last year CarPro forever changed the landscape for detailers and this year they do so again! CarPro Essence PLUS is NOT Essence… This is an entirely NEW concept! Essence PLUS is a unique SiO2 nano coating made from a distinct blend of ceramic coat repair agents, high gloss quartz resins, and hydrophobic nanoparticles! The concept behind Essence PLUS was an extremely glossy, semi-permanent nano-agent for repairing durable ceramic coatings, which may have been abused or mistreated over the course of time! Historically, the only option that a technician had was to polish or compound the damaged ceramic coating and then re-coat, starting from scratch. With Essence PLUS, we introduce you to the first NON-abrasive solution to repair fine swirls in a damaged ceramic coating while simultaneously increasing the gloss, hydrophobic properties, and cleansing the surface beneath! The surface is left with a smooth as glass feel and excellent protection and durability of up to a year or more! Not only does Essence PLUS work great on coated surfaces but also offers an excellent option for those that are not ready for paint correction, but would like to add gloss and protect the paint!
    Preparation:
    • Wash with Reset, and decontaminate with Iron X, Spotless, and if needed Tar X. Wash and rinse thoroughly.
    • Dry vehicle and wipe down with CarPro Eraser for clean oil free surface
    Via Dual Action Polisher:
    • Prime CarPro Gloss pad with Essence PLUS
    • Apply with no pressure in multiple overlapping passes on speed 1-3 across 24” x 24” (60cm x 60cm) section
    • Wipe off with CarPro Microfiber Towel
    • Clean pad with brush and apply 4 Pea size drops
    • Move to next section and repeat steps 2 through 4
    Via Hand:
    • Affix CarPro Gloss Pad to CarPro hand applicator strap tool
    • Apply Essence PLUS to the CarPro Gloss pad
    • Without pressure, apply in overlapping figure eight motions across 24” sq. ~ 36” sq. (60cm x 60cm ~ 90cm x 90cm) section.
    • Allow to dry to a slight haze and wipe off with CarPro Microfiber Towel
    Precautions:
    • On coated surfaces – If using machine, use only with CarPro Gloss pad
    • On coated surfaces – Avoid “edging” pad into a curve and keep pad flush with paint
    • Keep container tightly closed after use
    • Keep container out of the sun
    • Do not ingest
    • Not for use as a primer
    Mini Pads (2″)
    There is a big demand for mini pads to use on many of the new smaller polishing systems, like the Rupes L DLX and DLX Kits. We made our famous orange, gloss and MF pads in 2″ sizes (50mm). These will sell only as the kit, which is show below.
    This is a new simple, but quality microfiber towel that measures 40cm x 40cm. One side has short loops and the other side has slightly longer loops. Very soft feel, great for coating wipe offs as well! In fact, from this day further, it will be replaced in each CQ Finest kit instead of the Suede Microfiber Towel[/URL].
    New 1L Bottles
    From this day forward, all of our 1 liter bottles will be in grey color, instead of the clear bottles you are all used to now. This will allow us to have extra protection from UV rays and sun light, allowing for better storage and shelf life. We are also changing the safety child caps as well with a much better quality cap. Overall, our 1L bottles will be a much higher quality.
    Last edited by The Guz; 11-01-2016 at 12:06 PM. Reason: Removed hyperlinks to competitor site
    Senior Member Mike@DedicatedPerfection's Avatar
    Feb 2011
    Belleville Il
    12,251
    Re: 2017 CarPro SEMA Products
    Thanks for sharing Mike!!!
    Aug 2015
    263
    Re: 2016 CarPro SEMA Products
    Very interesting, thanks for sharing. We should probably start a thread to cover the newly released products at SEMA. I've already seen various things like a new Boss mini rotary polisher and about a dozen new products from CG (no surprise given the sheer number of products they have) including a Blacklight car wash soap. I'm sure many more to come.
    Senior Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    Yay... new towels in Finest kits
    Looking forward to trying that waterless wash
    Retired Professional Detailer
    Senior Member PreludeVTEC01's Avatar
    Jan 2014
    Atlanta, GA
    248
    Yay!! New Stuffs!! I am about out of waterless wash too!
    My Flickr Page
    Senior Member pheerix's Avatar
    Apr 2015
    994
    Waterless wash looks very interesting. Hope it doesn't streak like some of the Reload horror stories I've heard.
    Senior Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,774
    Quote Originally Posted by zmcgovern45 View Post
    Dude. The new waterless wash is EPIC! It's like wiping on gloss and the cleaning ability is amazing. Oh, and you can't make it streak even if you try. Just clean the surface and walk away.... no need to buff like crazy until the surface is 100% dry because any left over streaks will evaporate better than glass cleaner. Stuff is ridiculous.
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
    Aug 2015
    263
    I see Carpro has the products available now through their site. The ECH2o is $15.99 for .5L / $24.99 for 1L. Per the instructions, 1L makes 7 gallons of QD at 1:25 and 4 gallons of WW at 1:15. Also says it works well on plastic and rubber trim. Very interesting product.
    In time out
    Sep 2014
    Johannesburg,South Africa
    1,631
    Essence Plus looks like a maintenance product for ceramic coatings and/or a stand alone LSP. Basically Essence without abrasives.
    Thanks for the Sema product updates Guz!
  10. #10
    Jun 2013
    Lawndale, CA
    6,589
    Quote Originally Posted by boomdone View Post
    They are now up on in the store.
    CarPro ECH2O Waterless Wash & Detail Spray 1 Liter
    CarPro ECH2O Waterless Wash & Quick Detail Spray
    CarPro Essence PLUS
  1. SEMA 2016 Video: Griot's Garage Polisher, Pads and Products
    By Mike Phillips in forum Company & Forum News Headlines
    Last Post: 11-13-2016, 04:05 PM
  2. 2016 Gyeon SEMA Products
    By The Guz in forum Auto Detailing 101
    Last Post: 11-05-2016, 08:19 PM
  3. 2016 GTechniq SEMA Products
    Last Post: 11-04-2016, 09:29 AM
  4. 2016 Griot's Garage SEMA Products
    Last Post: 11-02-2016, 10:45 AM
  5. SEMA 2016 New Products
    By VISITOR in forum Off-Topic
    Last Post: 10-30-2016, 09:55 PM
» February 2020
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
