Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
  1. #41
    Feb 2019
    Santa Clarita, CA
    37
    Re: HD Speed Topping Question
    Quote Originally Posted by CAdetailer View Post
    Speed with an immediate top of 845 or now I usually use double coat (paste version of 845). Speed alone in so cal is 30 days max with lots of impurities imbedded, speed with 845 is about the same with a little less impurities imbedded, BUT speed with double coat is 2 months and very few impurities imbedded.
    Topping with poxy I found the poxy looks good but it's thin, doesn't feel protective and usually wears off in 30 or less.
    I really like the speed/ double coat but I'll be looking in to ceramic coatings to see if I can avoid all this work and washing & double waxing every 2 months vs just washing every month and coating once or twice a year?
    I used the HD Poxy for the first time on my son’s car about a week or so ago and the reflection doesn’t seem to pop us much compared to when I first put it on. Also compared to my vehicle, which still has a nice reflection to it after using Duragloss about two weeks ago.
    Wish I didn’t buy such a big bottle of the HD Poxy and should have just stuck with Duragloss. Oh well, you live and you learn and since this is my first time detailing any of my cars myself and just trying to test out the different products. I might just give the HD Poxy to family
  2. #42
    Sep 2017
    Sweden
    3,022
    Quote Originally Posted by Calendyr View Post
    This kind of question come up from time to time and I still cannot understand the regulars here posting answeres like yes, top it with this or that...
    HD Speed is an AIO. You use an AIO to save steps. So if you are gonna put a dedicated protectant after correcting, why use an AIO? You will get far better results in the correction step with a one step compound than with Speed. So instead of using Speed to correct, then apply a sealant on top (that will very likelly melt the montan wax it contains with it's own solvents and lay down a more durable LSP), just use a one step and apply the sealant you want. You will get far better results doing this than what you are planning to do.
    I agree with you that I have also trouble to see the benefit with an AIO and then topped. The AIO I have you get at least 3-4 months from and with good abrasives in it to correct wash marring and minor swirls on a rock hard VW clearcoat. But use an AIO with less than a month from I suspect you would be reapply a LSP and some kind of decon wash maybe soon again.
    What I have read about with the use of an AIO and then topped. Is that you skip the step with wipe it off until you are finished. And can polish a little faster this way. Also since leaving it on you have easier to see where you have polished. Just what I have seen in the debate about it.
    Don't know how it is since many polishes now days is water based. If a pure polish has less of the cleaning ability than the solvent based ones. Then even if they are water based they use an emulssion solvent which is soluble in water.
    If I would top Speed I would look at a Montan wax based wax. So even if you would desolve the Speed you still get the looks from Montan wax. BLACKFIRE BlackICE Hybrid Montan Sealant Wax and Dodo Juice Purple Haze is 2 waxes with Montan wax in them.
  3. Likes Paul A., acuRAS82 liked this post
  4. #43
    Junior Member Sports Fan's Avatar
    Jan 2019
    82
    Here's one thing I don't understand. People act like topping Speed is odd...because it already contains a wax/sealant....but wouldn't that make adding a second coat of anything to anything a bit odd as well? For example, if adding a layer of Poxy on top of Speed is odd...wouldn't adding a second coat of Collinite 845 on top of Collinite 845 odd as well?
  5. #44
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    Quote Originally Posted by Sports Fan View Post
    I think It's because the protection qualities of Speed are perceived (and in some cases demonstrated) as short term.
    At that point one of two things might happen.
    1. The topper will experience a short lifespan degrading as Speed degrades. This assuming Speed itself fails in a short time span.
    2. The solvents in the topper remove the protective component of Speed, negating It's use in the first place where using a dedicated polish would have made more sense.
    I'm not really into topping AIO products unless It's a durable polymer like DG 101 or 501. From there I'll apply a carnauba wax if I feel so inclined.
  6. #45
    Jun 2013
    Montreal, Quebec
    3,996
    Yes, it is actually useless. The solvent in the product disolves what ever is on the panel. You are not gonna get any benefit by layering.
  7. #46
    Jan 2019
    82
    I've heard that Speed generally lasts a month to maybe two months tops....whereas Poxy (which is the protective wax/sealant contained in Speed) can apparently last anywhere between 3 to 6 months (generally 4 or 5) by itself.
    Hmmm....interesting. According to 3D, Speed is 25% Poxy (the other 75% is Polish+ and some other chemicals found in Adapt, Cut, etc., or some variation thereof)....and since Poxy is a wax/sealant and doesn't contain any abrasives or solvents that should dissolve or diminish anything (simply bond to the paint) it must be the solvents from the polish portion of Speed that would dissolve or diminish the protective qualities of Poxy. But if that's the case, why would Poxy be included with Speed in the first place? I understand people saying that the better approach may be to polish with Polish+ and then apply Poxy for better paint correction/enhancement and longer, more durable protection....but I've read where people have topped Speed with Poxy and other waxes and sealants and extended the durable by several months...so it is somewhat confusing, in all honesty.
  8. #47
    Jun 2013
    Montreal, Quebec
    3,996
    Yes because when you try to "top off" speed, what actually happens is that the solvent in your topper (Proxy) will liquify the wax on the vehicle and it will mix with Proxy. Then when it cures, you have a mix of the two products bonded to the paint instead of the original wax. So if you mix a 1 month product with a 6 months product, you can expect a durabilty of both combined... so something like 3-5 month maybe?
    If you use a pure polish instead of speed, you will get better paint correction and no protection. Then when you apply Proxy, you get the full benefit of that sealant (6 months).
  9. Likes dlc95, Sports Fan liked this post
  10. #48
    May 2013
    Rochester Hills, Mi
    6,016
    To keep waxes and sealants suspended in an emulsion, solvents or some type of softening agents need to be used to keep these in a liquid or semi liquid state. Once applied to the paint, exposure to air caused the wax to dry. As this happens, the solvents flash off leaving the protection behind after the residue is removed.
    These solvents might be (and probably are) strong enough to have an effect on Speed.
  11. Likes Sports Fan liked this post
  12. #49
    Super Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,622
    It's pointless to top an AIO in my opinion, because I can find plenty of polishes that correct as well and clean out from my pads better than AIO. Then I'll just follow up with an LSP that is more durable. So.... Why would I do the same amount of work and time with an AIO and follow that up when I can do better in both steps?
  13. Likes BudgetPlan1, SWETM, dlc95 liked this post
  14. #50
    Regular Member Avgguy's Avatar
    Jul 2015
    Siloam Springs AR
    185
    I wouldn't wipe it down. I used HD Speed & topped it with 845 (3 coats) back in late August.
    Although the beading isn't quite what it was right after I applied this combo, 8 months and one awful NY winter later it is still beading water very, very well.
    Hope this helps.
    Ok, so it's almost a 3 year old post but I have the same experience.... top Speed with 845 and I get 8-9 months.... not a scientific test but eye test it's still beading well after 8 months. If I DON'T top Speed it stops beading after 6-8 weeks max.
    Help me understand why it's not worth topping/topping doesn't work/useless, etc. (provided I decide to invest the extra time to top). Not being argumentative just wanting to understand.
  1. Topping HD Speed with sealant
    By soobaroo in forum Ask your detailing questions!
    Last Post: 06-02-2018, 09:35 PM
  2. Topping a speed wax
    By bill57 in forum Auto Detailing 101
    Last Post: 11-05-2014, 09:19 PM
  3. Topping question
    By draganer in forum Auto Detailing 101
    Last Post: 06-30-2014, 10:34 PM
  4. Question about topping...
    By Supergus1 in forum Auto Detailing 101
    Last Post: 04-10-2014, 03:54 PM
  5. Question on Topping AIO
    By BTLew81 in forum Auto Detailing 101
    Last Post: 10-04-2012, 12:02 PM
