» Detailing Classes
Results 1 to 8 of 8
    Senior Member Coopers ST's Avatar
    Nov 2013
    Firestone, CO
    1,254
    Pads for GG6 and HD sp
    Hey all,
    I have a question about pads for a GG6 when using HD Speed. Right now I have a bunch of 6.5" pads, I am thinking of getting a new backing plate and 5.5" pads that I will mainly use HD Speed with.
    My first question is, will I see better results, or get the same results easier/quicker with the smaller pads?
    Second question is, can I get away with just one color pad with just HD Speed?
    Third question is, what color(s) would you get for HD Speed?
    Last question is, what pad would you get?
    thanks for your help and insight, all the different pads have always confused me.
    Brad
    ​1991 BRG Miata
    Brad's Detailed Touch
    https://www.facebook.com/Bradsdetailedtouch1
    Senior Member choijw2's Avatar
    Jul 2015
    781
    Re: Pads for GG6 and HD sp
    Pad size won't change the result, but I do find smaller pads correct little bit faster when used with same machine.
    (cutting power of a pad increases as pad gets smaller and thinner)
    Your third and last question is basically the same thing, since every manufacture have different colored pads.
    Anyways, AIO polishes can be used with all types of pads, such as polishing pads, finishing pad, even cutting pad, depends on the paint condition, but most people uses polishing pads for good cutting power and high gloss finish.
    I personally use Buff and shine green polishing pad for most AIO work.
    but I also use LC hydro tech orange polishing pad, meguiars polishing pad as well depends on how many cleane pads I have available lolll
    Please like my page
    Jae @ ONYX Detail Garage
    Senior Member custmsprty's Avatar
    Apr 2012
    7,352
    I have used Orange B & S or LC Flat pads exclusively with HD Speed with amazing correction and finishing results. Orange is and will always be my first go to pad with Speed. The BMW I did on the HD AG product page was with my Duetto and an Orange pad.
    3D Professional Detailing Products, HD car care, 3D HD
    2019 Nissan Rogue SL
    Nov 2013
    Firestone, CO
    1,254
    Quote Originally Posted by custmsprty View Post
    I am using orange flat pads from LC also, just the larger 6.5 inch ones.
    ​1991 BRG Miata
    Nov 2013
    Firestone, CO
    1,254
    So you guys are thinking my money would be better spent someplace else other than a new backing plate and a bunch of 5.5 inch pads?
    ​1991 BRG Miata
    Senior Member Joe@NextLevelDetail's Avatar
    Jun 2015
    1,929
    5 inch plate and pads will make your machine more agressive.
    You can run 6.5 inch pads on the griots 6 because of the power and torque the machine has, on the pc 6.5 inch pads make the machine less agressive. But with the griots you'll be ok.
    If your working on big wide open panels go 6.5 inch, if your working on smaller panels with countour go 5.5 inch.
    Either way it's still a need to go 5 inch when you need it.
    I suggest you get the 5 inch griots vented backplate, it's a plate designed low profile with cooling holes to maximize paint correction power while keeping pads cool.
    And the pads i reccommend? Boss pads of course, they are low profile witch will enhance and accelerate the paint correction process. And make your griots garage 6 inch a beast.
    https://youtu.be/u_bu5uQ-6zc
    Check out the youtube video I made using the griots 6 and the white boss pad.
    I would reccommend the orange boss correcting pad with HD speed.
    And I wouldn't prime my pad with HD speed as that will cause the pad to gum up really fast.
    Senior Member Dereksdtail's Avatar
    Jul 2014
    1,201
    I've used speed with mf,orange,white and green pads. It just depends on the situation and budget. Speed is so versatile it can cut decent or just enhance gloss, love the stuff
    Nov 2013
    Firestone, CO
    1,254
    Quote Originally Posted by Joe@NextLevelDetail View Post
    So this backing plate Griots Garage 5 Inch Vented Orbital Backing Plate
    Or this one Griots Garage BOSS 5 inch Backing Plate
    I figure I may as well get a 6 pack of pads
    Griots Garage 5.5 inch BOSS Foam and Microfiber Pads - 6 Pack
    I have:
    2 microfiber (I done have any in any size)
    2 orange
    1 white
    1 black
    I have 15 plus orange 12 white 5 black and 3 blue in 6.5 inch so do you think this is good, or should I swap out something?
    thanks
    Brad
    ​1991 BRG Miata
  1. Meguiars ultimate compound/polish with lake country pads or hex logic pads
    By Delicate Touch Auto in forum Products Guides
    Last Post: 08-16-2016, 08:20 PM
  2. Microfiber Cutting pads VS polishing/finishing pads, any difference?
    By coupe07 in forum Wool & Foam Buffing Pads
    Last Post: 05-15-2015, 08:21 PM
  3. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  4. CCS Smart Pads™ Dual Action 5.5 inch Foam Pads by Lake Country
    Last Post: 01-08-2008, 08:03 AM
  5. Replies: 5
    Last Post: 10-17-2006, 02:19 PM
» April 2020
293031 1 2 3 4
26 27 28 29 30 12
