Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    May 2014
    302
    Dr. ColorChip blending solution
    Just was wondering if anyone used Dr. ColorChip blending solution that removes excess paint, but leaves it in the lower spots (chips) with non-Dr. ColorChip paint. Reason I ask is because I have a spot on a customer's car with many very small chips. The Dr. ColorChip method would work perfectly only I am smearing Duplicolor paint over the spot and using the Dr. ColorChip blending solution to hopefully remove the excess paint around the tiny chips. Anyone try this? I would assume all the blending solution is mainly a paint thinner. I have no time to order the Dr. ColorChip paint which is why I am considering this.
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    Re: Dr. ColorChip leveling fluid
    I've done it with lacquer clearcoat from Wurth before, but never duplicolor.
    Super Member DaveT435's Avatar
    Jun 2012
    Arlington Texas
    3,982
    Re: Dr. ColorChip blending solution
    You'll want to add some mineral spirits to it. It will help remove the paint faster. This info came from Dr. Colorchip to remove their product more effectively.
    2015 F-150 Crew Cab Lariat
    2016 Chevrolet Camaro 2SS
    May 2014
    302
    Quote Originally Posted by Audios S6 View Post
    Hmmmm....did you have good results with the blending solution removing the excess clear?
    Jun 2016
    Quote Originally Posted by DaveT435 View Post
    Hmm, what about pure Naptha?
    May 2014
    302
    Anyone else try the blending solution on touch up paint besides Dr. ColorChips?
    Super Member builthatch's Avatar
    May 2008
    east coast
    2,352
    Quote Originally Posted by 98LowRanger View Post
    in the video with Mike Phillips, the dude from Dr. Colorchip specifically says SealAct won't work with other touch up paints.
    but then there is someone on this forum that used it on some old non-Dr. Colorchip touch up repairs and said it leveled them to a degree.
    Regular Member SirTanon's Avatar
    Dec 2014
    156
    So here is the question then. What can I use as a leveling liquid for standard touch-up paint on my Ford Fusion, for example?
    Super Member MarkD51's Avatar
    Oct 2012
    Sheboygan Wisconsin
    3,130
    Quote Originally Posted by SirTanon View Post
    Dr. C-Chip Sealact Solution works extremely slow and not very effective if at all on leveling factory type or Duplicolor type Touch Up Paints. I have tried it on a custom Cal Vue Mirror on my Tahoe that was touched up years prior with Duplicolor Paint, and while it did somewhat work, I sure used a lot of elbow grease, and a lot of Sealact product.
    But what might work better, is a 1-2 punch combination of Langka, and then Sealact after.
    Langka Blob Remover is designed to work with Factory Touch Up type Paints.
    I myself tried Langka many years ago, and to me, it was a very "touchy" product with rarely achieving desired results. As 1 or 2 swipes too many with the product would then remove too much, or all of the touch up paint from the repair area.
    But still, it might be a worthy product to have on hand to try to use it as I mention above, or to remove previous poor attempts that you, or someone else has done with touch up repair.
  10. #10
    Jun 2014
    Chandler, AZ
    3,360
    To the OP, I would highly consider using the Dr. Colorchip system as an offering. Contact them about the partner program for detailers. It's what I use on all customers vehicles. I just took care of some rear bumper rash on a vehic today using the squeegee method. Came out great...
    The shipping is pretty quick, however, I just did a 2012 Mustang and the customer asked the day before if the could get the rock chip repair. He paid the over-night shipping.
    This Merc was peppered:
    LSN Autodetailing - 2007 Merc E350 w/ Rock-chip repairl
    Bumper cover torn up by sheet metal on highway:
    Slide Show
    Road Rash fix:
    Slide Show
    Another road rash hood taken care of (several pictures deep into photo album):
    Slide Show
  1. dr chip blending solution
    By Bierman in forum Auto Detailing 101
    Last Post: 10-08-2016, 11:10 AM
  2. Need help blending!
    By Xzavier247 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 03-08-2013, 12:54 AM
  3. Solution Finish: Short Term Solution?
    By swanicyouth in forum Auto Detailing 101
    Last Post: 12-20-2012, 10:38 AM
  4. Solution Finish - The Solution To Dull, Faded Plastic & Vinyl Trim
    Last Post: 01-26-2012, 10:12 AM
  5. Blending
    By kdubski in forum Ask your detailing questions!
    Last Post: 12-14-2010, 12:38 PM
