What are these for? Hose washers?
My foam gun came with 2 of these washers inside the connector. What are they for and do I need them?
Re: What are these for? Hose washers?
[QUOTE=uhohitsstevo;1378992]My foam gun came with 2 of these washers inside the connector. What are they for and do I need them?[/QUOTE
Is that the hand sprayer you are holding upside down? If so, yes you need a washer to connect to your water hose.
[QUOTE=Rsurfer;1379007]
Originally Posted by uhohitsstevo
My foam gun came with 2 of these washers inside the connector. What are they for and do I need them? [/QUOTE
Yes it's the sprayer and I used it without and it worked fine?
There for keeping water from coming out the seems
I use Teflon tape anyway on the tip and with no washer it was fine so I will just put them aside
Wait, you use Teflon tape on the male end of your garden hose?
no on the end that goes into that. i use it on my hose, the part that screws into this
I'm assuming these are for if the hose does not screw all the way into the nozzle, almost to fill the extra spot that is not able to get screwed in because the male end is not long enough (if that was the case)
What about using Teflon tape?
By SuperClean33 in forum Auto Detailing Tools and Accessories
Last Post: 01-02-2017, 02:23 PM
By cc rider in forum Auto Detailing 101
Last Post: 11-09-2014, 08:40 PM
By Lexi65 in forum Auto Detailing 101
Last Post: 10-13-2013, 06:24 PM
By Alpham911 in forum Ask your detailing questions!
Last Post: 08-15-2011, 11:31 PM
