94 Camry oxidation, product recommendations?
Hello all,
My fiance's 94 Camry has some pretty obvious oxidation that I would like to try to improve if possible. I have a Porter Cable 5424, full set of pads, and several compounds to try. I hesitate to just go after it, because I recall reading somewhere on this forum that these old Toyotas are single stage paint, and I am not knowledgeable on working with these finishes. Anyone have suggestions, either technique, pad type, or product recommendations are all appreciated! On my shelf right now I have Meg's 83, Meg's fine cut #2, and Menzerna SIP. Happy to try something new.
And here's what the paint looks like on the other side, not heavily oxidized. The rest of the car looks pretty darn good for its age! I'd love to make it look a little better.
Re: 94 Camry oxidation, product recommendations?
That looks like clearcoat failure to me.
Clearcoat failure is common for older, neglected cars, especially in geographical areas of intense sun.
If it is clearcoat failure there's nothing that will fix it except a new paint job. I cover this in my how-to books and also here,
The Clearcoat Failure Photo Gallery Archive
Ah darn, I was hoping it was single stage paint. I can't remember where I read that Toyota used single stage paint up into the 90s, that's where I got my hopes from. Thanks for your help!
You can probably get it painted for a lot less than Mikes estimate. You do get what you pay for when it comes to repainting though. Mostly likely even a relatively poor paint job will still look better than clearcoat failure.
Thank you both for the replies! I have often thought about how mechanically sound and otherwise well-maintained the car is, it's too nice of a thing to just throw away over aesthetics. Maybe I'll look into a cheap paint job, as mentioned above, it looks a lot better than clearcoat failure. Thanks again for the help. I may mess with it a bit this weekend anyway to see if I can make it look a little better, but good to know for sure what the problem is.
By Tino7 in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-22-2016, 08:48 PM
By jarred767 in forum Auto Detailing 101
Last Post: 03-08-2016, 08:04 AM
By Canehdian in forum Auto Detailing 101
Last Post: 06-06-2015, 09:20 PM
By Vettecor in forum Products Guides
Last Post: 04-15-2013, 02:24 PM
By roberthathaway7 in forum Auto Detailing 101
Last Post: 01-09-2013, 08:18 PM
