Results 1 to 10 of 10
Thread: Metal halide
    Super Member poyo150's Avatar
    Dec 2015
    226
    Metal halide
    I am looking at light chart to see what is the closes thing to sunlight. I found that metal halide produce more white light. The only draw back is that their expensive and the amount of lumens it produces is really strong. I think this is over kill but I might be wrong.
    Has anyone try this light on a car to find scratches. What do you use to find swirl marks without sunlight?
    Sent from my LG-H811 using Tapatalk
    Super Member Cabrio's Avatar
    Sep 2014
    Chicago Burbs
    312
    Re: Metal halide
    Reading your post brings visions of Chevy Chase and Christmas Vacation to mind
    What sort of fixture would you use? I have a pretty strong cycling light that I occasionally use that produces 600 lumens and there are times when I think this is a bit of an overkill.
    Dec 2015
    226
    Re: Metal halide
    I'm trying to find the perfect ligh to find swirl marks without sunlight. I have bought a Xenon Hi-Beam. Did a test on my sunset Orange 350z and it was not good to find swirl. I will test this light again with distance and see if they show up more. I'm getting ready to start my first year of detailing once it gets nice and warm in Chicago.
    Sep 2014
    Chicago Burbs
    312
    Re: Metal halide
    When I use my cycling light, I find that I have to put some distance between the paint and the light. The center of the beam is so bright, it's hard to find the swirls. But if I pull the light away and focus away from the center, I start to find the swirls. Detecting swirls on a color like sunset orange...I can understand the challenge.
    Dec 2015
    226
    Re: Metal halide
    I will experiment with the lighting once I start to detail my Z.
    I was never a fan of black cars. I like color cars but the colors vary for each car to look good.
    Super Member Jim w's Avatar
    Dec 2015
    South Jersey
    310
    Re: Metal halide
    Metal Halide is a very rich UV source. Good chance of
    a bad case of sunburn depending how close you are
    to the lamp and how long you are exposed to it;
    lots of heat as well.
    Jim
    Dec 2015
    226
    Re: Metal halide
    Thanks you for the info. I was wondering if this produce UV or any harmful light.
    Dec 2015
    226
    Re: Metal halide
    I believe the that light produce about 600 Kelvin which is really hot
    Aug 2011
    Reisterstown MD
    1,128
    Re: Metal halide
    Do yourself a favor and go to LED lights. I have them in our shop and they show things direct sunlight doesn't
  10. #10
    Dec 2015
    226
    Re: Metal halide
    Ok for sure I will try them out. I was going to get a led tripod that was around $100 at home depot
  1. Replies: 3
    Last Post: 05-29-2020, 11:33 AM
  2. Replies: 8
    Last Post: 04-08-2013, 04:22 PM
  3. CG metal shine or metal wax
    By thrawn5499 in forum Auto Detailing 101
    Last Post: 05-01-2012, 10:02 AM
  4. Replies: 2
    Last Post: 05-16-2011, 12:09 AM
  5. check this baby out- metal halide!!!
    By CacheHX in forum Auto Detailing 101
    Last Post: 02-05-2010, 11:20 PM
