» Detailing Classes
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 57
  1. #41
    Senior Member Boudin's Avatar
    Mar 2012
    Southeast Louisiana
    453
    Re: LED v.s. Fluorescent lights in the garage
    9x Commercial Electric LED shop lights on ceiling ( from Home Depot about $40 each and can run 9 in series, regular plug ), 6x T5 LED fixtures on each wall ( eBay/amazon specials, regular plug, can run 6 in series) , dual par38s on photography stands if needed. The 6k color temperature works well on dark paint, the 4k color temperature is better with lighter colored paint. It's bright in my garage 😎 No problem with cold temps, but I live in South Louisiana.
    Sent from my SM-G930V using Tapatalk
  2. #42
    Junior Member Addison87's Avatar
    Nov 2016
    Erie pa
    I have 6 8ft fixtures with 4 4ft fluorescent bulbs in each fixture. 6500k daylight bulbs . In a 2 bay garage. It is just right for me. If im doing a final inspection on paint ill sometimes just turn them off and use only my Rupes pen light. Seems to work great for me .
    Www.erieluxurydetails.com
    Facebook- Luxurydetails
    Fine Auto Detailing Erie, PA
  3. #43
    Nov 2016
    Erie pa
    Also once I put a light gray exopy and clear coat on my floor it seemed to make things seem alot brighter and helped to reflect the light. Could be just me tho ☺
  4. #44
    Nov 2016
    Erie pa
    Love the lights mounted on wall!!
  5. #45
    Nov 2016
    Erie pa
    LED v.s. Fluorescent lights in the garage-img_5818-1_1491957450895_1-jpgLED v.s. Fluorescent lights in the garage-dsc_0593_1491008404790_1-jpgLED v.s. Fluorescent lights in the garage-img_0814_1492828284685_1-jpg
    Hows cars look under the lights
  6. #46
    Apr 2017
    I would def go with LED personally. They last virtually forever, don't hum (maybe it's just me but it drives me nuts), are super bright and don't fade over time, don't take anytime to turn on and use less energy. I have tall ceilings in my garage and I installed a hot red light to match my Camaro. Here's the ones I used http://cheaphighbays.com/product.html?l=highbay-a
  7. #47
    Senior Member asap2stacks's Avatar
    Mar 2016
    Maryland
    551
    6500k T8 lights work best or T5
  8. Likes TTQ B4U liked this post
  9. #48
    Senior Member RippyD's Avatar
    Jan 2016
    Portland, OR
    1,150
    Just went through this - had several florescent fixtures that were giving me problems. Looked like ballasts were going bad in a couple. I also needed more light. Costco had LED fixtures are a decent price so I bought a bunch of them. Total cost was about the same as getting more florescent and fixing the bad ones. The light is better overall and the fixtures are smaller so I could get them into dark areas more easily. These can be hard wired but also have regular plugs so it can save you wiring if you're not up for that.
    The one downside is that they have a delay before coming in. No flicker like florescents, but it takes a second for them to come on which is a little annoying. No regrets, and they take practically no power so I don't care when the kids leave them on overnight.
    2006 LR3 White // 2014 Boxster Agate Gray // 2012 Sentra Aspen White
    Sealant test resultsxxxxxDilution ratio chartxxxxxWheel cleaner info
  10. #49
    Dec 2015
    502
    Quote Originally Posted by RippyD View Post
    Are you using the pull chains or do you have them wired to a switch? If you have them on a switch, they make dedicated LED switches. It will eliminate the delay.
  11. #50
    Jan 2016
    Portland, OR
    1,150
    Interesting - I'll look into that. They're all wired to a wall switch. But I have to admit I don't see how the switch could be an issue - it's just a typical single-pole light switch. All it does is make contact to complete the circuit. What would an LED switch do differently to eliminate the delay?
    I assumed the delay was due to the circuitry in the lights.
  1. Garage lights
    By parshisa in forum Auto Detailing 101
    Last Post: 01-16-2018, 04:04 PM
  2. Lights for garage
    By errolt in forum Auto Detailing 101
    Last Post: 06-30-2017, 05:47 AM
  3. what fluorescent tube temperature for garage?
    By octane in forum Auto Detailing 101
    Last Post: 03-15-2016, 03:44 PM
  4. Need help about Led lights in my garage....
    By ViGi in forum Hot topics & Frequently Asked Questions
    Last Post: 07-10-2014, 06:47 PM
  5. Lights for the garage......
    By YankeeFan in forum Auto Detailing 101
    Last Post: 08-08-2008, 07:37 AM
Members who have read this thread: 78
» July 2020
