Im leaning towards rear drum brake parts clanging around. That is IF you have rear drum and it sounds like it is coming from the rear. You havent given much info.
I feel as if it is coming from the front. The car is 8 years old with about 25,000 miles on it, It sounds like something is slightly grinding the metal or like it is clicking as you increase speed
Bill 1234
2004 audi a6 quattro (traded).
2015 Ford Escape 2.0l ecoboost 4WD
You should try posting this to a Audi specific discussion forum. The people on there will have the same or similar car and may have been through the same problem.
Hello all, Currently, I have a small mechanical problem on my older audi. I hear small amounts of pieces clicking together when driving. I recently changed my oil and got my tires inflated for the winter. I dont hear it alot, but it happens at high speeds (about 35 mph) and some other times. I also sometimes hear the brakes squeak very little. Should I get new brakes (thinking about brembos ) or just take it in to a mechanic
Clicking?.....if its from the engine it might need a valve adjustment...otherwise if its over bumps then check your bushings, axle boots, strut hats and check the ball joints.
if is grinding...then it could be wheel bearings or a dragging brake pad.
