» Detailing Classes
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Jan 2015
    997
    Re: I've never owned a large air compressor before
    Quote Originally Posted by dgage View Post
    That’s a good point 2black1a but I’m not sure they make such a 30 gal anymore. I’ve only ever seen less expensive ones. I’m assuming the motor you have is 220V to have that much capability and I don’t know that I’’ve seen a 30gal like that. Then again, when looking at 220V, I shift to 60/80-gal because those are most prevalent.
    Yes it is 220V. And like you, I haven't seen any 30G compressor's with the performance of this one either.
    It's manufactured by DeVilbiss and was marketed and sold by Sears under their Craftsman brand. They don't have anything close these days.
    I remember raving about its performance to my dad and brothers when I got it and they also went out and bought one. So there are three of these compressors in my family today.
  2. Likes dgage liked this post
  3. #12
    Jan 2019
    California
    287
    Hypothetically, could two 30-gallon compressor/tanks be connected in parallel? (Assuming unlimited cash, space, and power...). Would that have the effect similar to 60 gallons that fills quickly?
  4. #13
    May 2013
    TN
    347
    Quote Originally Posted by bofh View Post
    Yes you can combine two compressors. Putting them in parallel increases CFM, in series increases PSI. You’ll need a tee to combine them but also put an air check valve for compressors on each line so that one compressor isn’t able to pressurize the other compressor’s tank. And make sure each compressor is on a separate power circuit or you’ll likely trip the breaker each time the second one turns on since the initial power on load is greater than its running load. And if you use an extension cord, make sure it is beefy and rated for the greater initial power on amperage of your compressor based on the length of extension cord.
  5. Thanks bofh thanked for this post
  1. What was your very first car you owned?
    By Tango in forum Off-Topic
    Last Post: 11-12-2014, 11:53 PM
  2. How many cars have you owned?
    By MustangMikeFL in forum Off-Topic
    Last Post: 04-12-2014, 07:44 PM
  3. The worst vehicle you ever owned was...
    By cardaddy in forum Off-Topic
    Last Post: 01-12-2013, 09:13 PM
  4. 07/08 C6 Z06 has owned me
    By Detail in forum Show N' Shine
    Last Post: 10-14-2010, 08:19 PM
  5. New or pre-owned car opinions
    By t-bone in forum Off-Topic
    Last Post: 03-09-2008, 01:14 AM
Members who have read this thread: 40
» April 2021
28293031 1 2 3
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 1
