Re: Door Trim Outer Seal
Clean the rubber and try Ultima Tire and Trim or Gummi Pflege.
Hey Kurt, you out there? Would that plastic polish you use work?
After you get it right I would seal with Ultima T&TG.
:dancebanana:
Sky's the Limit Car Care
I have wondered this too for my cars. Are you sure its rubber? There is always removal and re coating as an option if your not able to bring it back.
2005 Subaru Impreza WRX STi - "Crystal"
2007 Mazda MX-5 Miata - "Mindy" (SOLD)
2011 Toyota Tacoma TRD Off-Road Dbl Cab - "Bruce"
+1
On a lot of cars, this is painted plastic. You could have something more like clear coat failure. Is the material hard or soft? If hard (likely), you may need a different approach.
Try tapping on it with your fingernail. Depending on the sound you should be able to tell if it is rubber, plastic, or maybe even painted metal.
I agree, check the material. I thought mine were doomed and went after them with DA and M105 Soft Buff Yellow/M205 Yellow, then sealed.
It's hardened plastic, and does look like a clear coat failure.
I thought it was plastic, but since you said it was rubber I recommend something for rubber. Try buffing it out with a 4" pad and 105/205 and then seal.
By Ncs0816 in forum How to Articles
Last Post: 06-20-2015, 04:06 PM
By Mr M5 in forum Ask your detailing questions!
Last Post: 06-07-2013, 02:04 PM
By what'sinaname in forum Auto Detailing 101
Last Post: 02-12-2012, 11:28 PM
By cwschulz in forum Auto Detailing 101
Last Post: 09-25-2011, 07:49 PM
By Matt in forum New Car Care Products
Last Post: 03-24-2006, 03:45 PM
