Results 1 to 3 of 3
    May 2020
    Removing tape residue from vinyl decal?
    I bought a vinyl decal from china for a project on my car. The decal was rolled up in a tube and a piece of tape had been applied to keep it tight. Well the tape or adhesive or whatever from the tape absorbed into the vinyl and nothing I have tried will remove it. I have tried water, soapy water, rubbing alcohol, lacquer thinner, etc. I assume it cannot be fixed? It was custom measured and machine cut to fit and cost $100 I don't want to buy another one.
    Removing tape residue from vinyl decal?-imagejpeg_0-jpg
    Super Member joebruin77's Avatar
    Jan 2019
    268
    Re: Removing tape residue from vinyl decal?
    I once contacted Xpel customer support to ask them how to remove tape adhesive residue that was stuck to PPF. They recommended a product called Rapid Remover Adhesive Remover. I think you can order it on Amazon. It is designed to remove adhesive residue off of decals, vinyl wraps, and PPF.
    One other idea-you may want to try alcohol based hand sanitizer. Place some hand sanitizer on the adhesive residue, let it dwell for 4 or 5 minutes, then rub it off with a microfiber. You might have to reapply 2 or 3 times.
    May 2020
    Quote Originally Posted by joebruin77 View Post
    There is no residue on the decal as far as i can tell. It seems like it is oil or something that has seeped into the material. I actually had an xpel shop install this and they could not remove the marks.
  1. Can the residue be removed without damaging the decal?
    By 2K4CE in forum Ask your detailing questions!
    Last Post: 06-02-2024, 03:38 PM
  2. Removing tape residue - help!!
    By AutoApollo in forum Auto Detailing 101
    Last Post: 07-11-2016, 08:25 AM
  3. Removing 3M tape residue?
    By digdug18 in forum Auto Detailing 101
    Last Post: 06-03-2015, 06:54 PM
  4. Removing duck tape residue
    By CAD in forum Auto Detailing 101
    Last Post: 02-22-2013, 08:04 PM
  5. Removing 3M Auto Adhesive Tape/Residue from Car (Side Scoops)
    By Ohio Detailing in forum Ask your detailing questions!
    Last Post: 04-17-2012, 12:41 AM
Members who have read this thread: 11
» July 2024
30 1 2 3 4 5 6
28 29 30 31 123
