Results 1 to 4 of 4
    Junior Member george type-s's Avatar
    Jul 2014
    Vaudreuil, Quebec
    67
    Megs M100 on a RAM 1500
    I have a black 2022 RAM 1500 that has a few scratches that are bugging me to say the least.
    You can't feel them with your nail (if that helps), so I tried the M105 with a yellow lake country pad on the 3401C polisher, it worked for some but not all.
    Upon researching for a stronger compound than the M105, I came across the M100, so I just ordered it now.
    However, I wanted to know, which pad do I need for this to work? Can I stick to the lake country yellow pad?
    Thanks in advance!
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Megs M100 on a RAM 1500
    If the 105 worked for "some" scratches but not others, that tells me the "others" are simply deeper and need more effort -or- you didn't work those areas as thoroughly. I would just make a few more passes with the 105 (if it's safe to do so based on your own risk tolerance).
    From a cut perspective, the 105 should be able to remove any "repairable" scratch.
    One downside to the 105 is that it has a fairly short cycle time before it starts to dry out. I'm not sure how the 100 compares in that respect.
    As for pad choice - I have no comment.
  3. Likes PaulMys liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    As a Ram owner myself, and having worked on handful of my friends' Rams, I can tell you that the clear coat is "medium/hard to the hard side".
    Like John stated above, you might want to make a few more section passes over the deeper scratches. And with slower arm speed.
    See what that yields before jumping up to a more aggressive pad/product.
  5. Likes dlc95 liked this post
  6. #4
    Jul 2014
    Vaudreuil, Quebec
    67
    Thanks for the tips!
    I'll give it another go, worse case, the M100 should get here in a few days and hopefully that solves it.
    Since you work on a lot of RAMs, is there any products that you would recommend for a black one?
    I usually do this on Honda/Acura & Toyota/Lexus, never tried it on the RAM:
    Meguiar's M105
    Meguiar's D30032 Correction Compound
    Meguiar's D30101 Finishing Wax
  1. meguiars m100
    By dougsrt in forum Auto Detailing 101
    Last Post: 06-20-2014, 09:46 PM
  2. Meguiars M100 for DA
    By Ginnova in forum Auto Detailing 101
    Last Post: 11-29-2013, 06:29 AM
  3. 05 Ram 1500 M205 and Megs UW
    By jankerson in forum Show N' Shine
    Last Post: 11-15-2013, 08:36 AM
  4. Okay m101 vs m100! Anybody !
    By Wes Bremec in forum Ask your detailing questions!
    Last Post: 02-27-2013, 04:42 PM
  5. Megs M100-Rotary and Wool Pad.
    By ElWichaco in forum Auto Detailing 101
    Last Post: 02-26-2013, 10:37 PM
