New to Me Car - Considering a DIY Ceramic Coating
Folks,
I just purchased a new to me, 2019 Audi A7 with 22K miles on it. The color is Firmament Blue. I got a few estimates for ceramic coatings but kinda would like to do the work myself. My concern is that I have zero experience working with coatings or doing any sort of paint correction. I've never worked with a machine buffer, either. While the car is in excellent condition, there are swirls, paint chips, etc, as to be expected on a 4-year-old car. My worry is ruining the appearance and paint of my car due to lack of experience, but the DIYer in me wants to tackle this project.
I've narrowed down the coatings to a possible 2- Adam's or Gyeon, but certainly open to others if they are easier to work with.
Can a novice with zero paint correction and ceramic experience pull this off? Do I need heaters and a zero-dust environment to make this work? Can it be done in the typical home garage without any issues?
I appreciate any advice!
Re: New to Me Car - Considering a DIY Ceramic Coating
You don’t need to do pain correction to apply a coating. You do need to thoroughly clean the surface. You will need to use a clay bar to rid the surface of bonded contaminants. If the surface has a rough or gritty feel, you need to use clay bar. If you are happy with the condition of the paint, just clean and apply coating. I have used both Gyeon Mohs and Gyeon Pure. Both are very easy to apply and remove.
With Pure, you can apply to a full panel or two before removing. With Mohs, you apply, wait for coating to”sweat or bead” then remove. This process only takes 30-60 seconds. Good luck.
I use a lot of Optimum Gloss Coat. I use it because it holds up well and is easy to use. It also looks great on the paint!
But I've been really impressed with the Meguiar's Hybrid Paint Coating. Holds up great, easy to apply and remove, and in one ongoing test repels dirt better than Cquartz UK 3.0 / Gliss combo.
That being said, I also really like the CarPro Cquartz UK 3.0, Gliss, and Lite. I just done care for actually using them.
Where I work I have to apply glass bottle coatings and I absolutely hate it. I'd rather clean toilets
Originally Posted by 757CA
Folks,
Congrats on the new purchase. Polishing is not hard. Tedious but not hard.
Which Adams coating and which Gyeon coating? There are a couple options for each brand.
Yes.
No
Yes
Do you have a friend with a junk car that you can try buffing using compound and polish ? What buffer will you use?
2022 Carrera S & Honda CRV Hybrid
2015 Lexus IS 350, 2016 Ford F-150
Cobalt 242 (8.1 L block, Volvo outdrive)
Thanks for the replies!
For Adam's I was considering the Graphene Ceramic Coating Advanced. For Gyeon I'm thinking the Q2 Pure Evo.
Thanks. Unfortunately, I don't have a car I could test out with. Maybe I could sneak a try with my wife's Subaru Outback! I also have figured out which buffer to buy.
Good choices but I'd also highly recommend Can Coat Evo. Doesn't get much easier and holds up well.
Megs hybrid paint coating and Optimum Gloss Coat are also very user friendly.
Thanks. Can Coat looks pretty good too.
I'm not a coating guy but I did recently use Meguiar's Hybrid Paint Coating and I can't imagine anything being easier to apply. For a first-timer, I would definitely recommend you give it some consideration. The results looked great, the finish was as slick (or better) than anything I've ever used, and after about three months it is holding up well with great self-cleaning properties.
Last Post: 01-05-2021, 07:04 PM
By joebruin77 in forum Auto Detailing 101
Last Post: 12-30-2020, 08:58 AM
Last Post: 03-28-2019, 02:09 PM
By driggett in forum Auto Detailing 101
Last Post: 02-04-2016, 07:15 PM
By Mike@ShineStruck in forum Auto Detailing 101
Last Post: 12-19-2015, 01:42 PM
Members who have read this thread: 5
