Damage free wheel removal - no marring sockets
I've seen videos of people removing wheels on high-end cars and the sockets they use appear to have some sort of coating around the outside of the socket to prevent marring or scratching of the wheel. Are these actually a thing or are they just being dipped in a coating (DIY)? I'd really like to get at least one for my car since I have very black and very shiny wheels that aren't going to look too good with a big silver gouge along the barrel of the lug nuts.
Re: Damage free wheel removal - no marring sockets
Nevermind. I should have searched Google first for "non marring lugnut sockets". It appears they are a thing and I can buy them locally. D'oh!
Just be careful and you won't need to waste money on these sockets. Try wrapping some tape around your standard sockets if your that concerned.
I have gloss black wheels on the Durango and when I need to remove the wheels I just take special care on how I remove the lug nuts. I do this for all our vehicles.
You ever play the game "Operation"? You know...where you have to be careful of not touching the sides or the buzzer goes off? Yeah same thing, lol. Don't touch the sides of the wheel lug hole.
I've never had an issue with marring/scratching on the outside of the socket/inside of the lug nut barrel, but there is an issue with the lug nut itself. What I've done there to minimize damage to the lug nut is take a piece of of heavy plastic sheeting (4 or 6 mil) and place it over the lug nut before installing the socket. It does help.
Originally Posted by
evo77
This. I work on cars for a living, and pride myself on being one of a rare breed that operates at Autogeek level regarding care and thought for peoples cars.
No matter what fancy socket you have, any spinning thing that makes contact with the lug recess stands to scratch it.
Full confession - I have one of the "non marring" sockets - I took the plastic jacket off it, and now you have an impact rated 1/2 (drive) socket with the about the outside clearance of a 3/8 (drive) thinwall socket. I virtually never use it any more. Most of the time if I have limited clearance, I use a deep 3/8" drive socket and a 1/2 adapter.
One other bit of advice - make sure when you're removing wheels you don't let the wheel cant as you're loosening the last lug, or you run the risk of your socket rubbing against the recess.
The reason I bought two is convenience . I open the drawer, I only have two to choose from. They are labeled to cheat.
Biggest reason I like the longer length is to pull them off the friction ring on the impact without using a screwdriver.
