The screen for the radio in my son's 2015 Ford Fusion isn't working. The radio works, but the screen doesn't. I went to the local salvage yard and bought the screen and electronics/console panel(?).
I might be wrong, but it looks to be a tad dusty. Maybe even dirty(sarcasm font). Any recommendations on what to use to get it clean? I'm afraid with my luck whatever I use on it will render it useless.
Spray some APC into a microfiber towel and go slow and don't mash the solution into the control buttons.
Get the old dirt soft and loosen it up with a soft detailing brush and wipe off with a clean microfiber towel as you go...
If you have an air compressor to blow it out as you go it will also help...
A detailing brush and a diluted APC. Dap the brush in the APC solution, shake some of it out, go over it a few times- use your head & common sense as far a s pressure goes, wipe with a MF towel. If you have any canned air like computer geeeeeks I/T folks use or compressed air lightly
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions-- Winston Churchill
The difference between genius & stupidity is genius has limits-- Albert Einstein
Thank you for the advice and to PaulMys for the laugh!
I started with a dry detailing brush and that took a lot of the dirt off. I happened to look at a pic of the original panel and noticed a difference. The replacement panel does not have buttons for the heated seats. No loss for me though. The screen which is what we needed most did work.
Clamp it to a big rock and hit it with a 4500psi pressure washer. Use the 0-degree tip to get into those tight areas.
J/K. Great suggestions above.
Figured you'd go with high pressure steam
I just might have to, and it would give me a reason to get a steamer.
You know were were just kidding
