Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,295
    Re: Clear coat aluminum wheels
    Give it a try, but you might need to step up to a rotary polisher with airway buffing wheels to remove the sanding marks. Please post some pictures of the process. Good luck!
    Super Member Rsurfer's Avatar
    Jan 2007
    13,713
    Quote Originally Posted by Will12785 View Post
    So here's the plan, now that the wheels are back from sandblasting.
    I'm going to wet sand them 600, 800, then 1000 grit.
    After that I'll use Wolfgang MetallWerk Aluminum Polishing Kit. Ill apply it with Lake Country 6.5 FLAT Pads starting with yellow, then white, then blue.
    Once it's fully polished I'll finish the job with Wolfgang Uber Ceramic Coating Complete Kit.
    Your going to polish sanding marks with a 6.5" pad? Is this a rotary or DA?
  3. #13
    Super Member opie's Avatar
    Mar 2021
    Pa
    875
    My advice before you do anything else...give Evans Detailing and Polishing out of chilton wisconsin a call. Those wheels would be right up his allie. Atleast ask for some advice.
    Evan knows his stuff and is damn good.
  4. #14
    Jun 2022
    Syracuse, NY
    Quote Originally Posted by Bobby B. View Post
    Thanks. I'll look into that.
    DA. If that won't work I'm open to suggestions. This is my first time doing this level of work.
    Quote Originally Posted by opie View Post
    I will look him up.
  5. #15
    Dec 2011
    Pompano Beach, Fl
    1,441
    The only way that I have ever been able to get rid of sanding marks is ending with 3600 grit paper, and using a hybrid wool pad on a rotary. A DA won’t touch it. I don’t know how you get a rotary inside all the complicated radaii and surfaces of a wheel.
    Glen
    21 BMW X2 M35i-(garaged in FL)
    (old and highly opinionated)
  6. #16
    May 2013
    TN
    1,347
    Quote Originally Posted by glen e View Post
    You can mount a buffing pad and use the side edge to get in pretty easily though those are often used with rouge bars for the polishing product. But I’d also agree you want to get up past 2000 grit before starting on polishing metal.
  1. Clear Coat Wheels
    By Willbeen in forum Products Guides
    Last Post: 03-26-2019, 09:36 AM
  2. Clear coated aluminum wheels
    By joleyred in forum Auto Detailing 101
    Last Post: 04-08-2018, 07:38 AM
  3. Clear Coat Wheels
    By h2chuck in forum Ask your detailing questions!
    Last Post: 04-01-2018, 04:47 AM
  4. Best Way to Polish 40 year old Lacquer Clear Coated Aluminum Wheels
    By Since1977 in forum Ask your detailing questions!
    Last Post: 04-24-2017, 10:44 AM
  5. stock clear coated aluminum wheels
    By 2012rscamaro in forum Auto Detailing 101
    Last Post: 03-09-2015, 08:31 AM
Members who have read this thread: 37
» August 2022
28 29 30 31 123
