Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Dec 2018
    7,170
    Re: cleaning pads after using Sonax EX 04-06
    Mckee’s has their pad rejuvenator on sale for $15 for July 4th sale. Awesome price
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Stuff is toxic with how bad it smells.
  3. #13
    Super Member Icarus's Avatar
    Oct 2019
    Ontario, Canada eh!
    269
    Never had a problem cleaning it out of my pads.
    Yet you still haven't offered what you use or methods that makes it so easy?! Please share!
    ·Ï¢årµ§·
  4. Thanks The Guz thanked for this post
  5. #14
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Icarus View Post
    See my previous posts on what I use.
  6. Dislikes Icarus disliked this post
  7. #15
    Jul 2020
    56
    Quote Originally Posted by luckydawg View Post
    To help them dry quicker I spin them on high speed on my rotary- slings everything out- guess you could do the same on a RO
    I do the same. Grab an empty bucket and rest the rotary on the lip. Most sling stays inside the bucket.
    Word of caution I think the high rpms' stretch the pad = reduced lifespan.
  8. #16
    Jan 2014
    SoCal
    1,122
    Add a di-limonene product to your cleaner ( I've added it to 3D degreaser @1:10 with distilled water(DW), pad cleaner packets @ a packet /gal with DW, APC's @ 1:10 DW - basically whatever I had a lot of or wanted to get rid of.). Make it equal to about 5-6 percent of solution. It will get your pads clean quick - even with AIO's.
    Put your pad in a container, pour a few ounces in and start working it. You use the container so you can dip the pad back in the cleaner that comes out as you work the pad (otherwise you would go through a lot of cleaner). Rinse the pad/container out and repeat. It usually only takes twice with and AIO. Though, you may want to put an ounce on the pad after the second rinse to work in and make sure you got everything out. If you wash your pads in a washing machine, you probably just need to do enough to get the gunk out.
    CitraBlast, CitraSolv, Citrol, they all work. CitraBlast is probably cheaper even though it's cut 50/50 with water. You just have to double the amount you add and shake it up. I've had good results using it though.
  9. #17
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    One thing i do before using a fresh clean pad is take a pad brush to it and get any dried bits out of it.
  10. Likes oneheadlite liked this post
  11. #18
    Oct 2019
    Ontario, Canada eh!
    269
    Quote Originally Posted by cleantechwa View Post
    Yikes, i ended up throwing away two pads didnt have the patience!
    No patience to spritz a used pad with cleaner and toss into a bucket overnight? Then taking 2-5min to rinse it out the next day or so and let it sit to dry?!?! How long does it take you to polish a whole vehicle??!
    ·Ï¢årµ§·
  1. Sonax for wheels, what do you use for tire cleaning?
    By Bobbykart in forum Auto Detailing 101
    Last Post: 01-24-2021, 08:31 PM
  2. Sonax intensive cleaning brush.
    By PA DETAILER in forum Auto Detailing Tools and Accessories
    Last Post: 08-02-2020, 07:26 AM
  3. Pick my pads, PLEASE - White BMW - Sonax PF
    By mvolps22 in forum Auto Detailing 101
    Last Post: 04-28-2020, 11:36 PM
  4. Thoughts on Sonax pads vs. Lake Country vs. Flex pads?
    By Detailchick in forum Auto Detailing Tools and Accessories
    Last Post: 03-21-2020, 08:06 PM
  5. Cleaning wax/sealant out of foam pads with the Grit Guard Cleaning bucket?
    By TotalNewbie in forum Wool & Foam Buffing Pads
    Last Post: 05-29-2013, 08:43 PM
