Results 1 to 5 of 5
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    400
    Tint adhesive removal
    Hi y'all. I had my son wait to remove his rear window tint that failed on a hot summer day. This was today lol. He was able to remove 95% of the tint film, but none of the adhesive removed with the film. I had him try isopropyl alcohol, but he says this didn't work at all. Do any of you know what you can use to remove this adhesive as far as chemicals go?
    Aug 2015
    Andover, MN
    1,727
    Re: Tint adhesive removal
    I just posted something similar to this here and on the sister site. Helpful folks chimed in with recommendations for: Tar-x (or other tar remover), 3m adhesive remover, and mineral spirits. Also watch your interior trim as you’re using chemicals around them.
    For smooth glass I know fresh razor blades often come into play as well.
    Good luck!
  3. Likes PaulMys, Azure liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    3M General Purpose Adhesive Remover.
    And like John stated above, be VERY careful not to get any on interior plastics.
  5. #4
    May 2013
    TN
    1,768
    Also don’t use razors on a back glass that has defroster lines or you might break them. You also might want to test the rear defroster before and after to make sure it still works when you’re done.
    I’d probably suggest the 3M Adhesive Remover and use some plastic, absorbent material on top of that, and tape to protect the trim and upholstery nearby.
  6. Likes Azure liked this post
  7. #5
    May 2013
    Indianapolis, IN
    400
    Quote Originally Posted by oneheadlite View Post
    Good luck!
    Quote Originally Posted by dgage View Post
    Thanks to all! This is very helpful.
  1. Help with Adhesive Removal In New Car Decontamination
    By Macpage in forum Auto Detailing 101
    Last Post: 01-07-2017, 03:06 PM
  2. Need to remove adhesive without removing tint...help
    By Mk23 in forum Ask your detailing questions!
    Last Post: 10-18-2011, 09:09 PM
  3. Window Tint Adhesive Removal?
    By Lowprofile in forum Auto Detailing 101
    Last Post: 09-13-2009, 08:43 PM
  4. Old adhesive removal
    By t-bone in forum Auto Detailing 101
    Last Post: 11-15-2007, 09:25 AM
  5. Tint removal?
    By RacerE7773 in forum Off-Topic
    Last Post: 03-27-2007, 03:29 PM
