First time using Iron Remover, a couple questions
Hey, everyone,
I am going to use the Turtle Wax Wheel Cleaner and Iron Remover for the first time to remove iron particles on my car's paint. I have a couple application questions:
1) I also need to use a clay bar on some of the paint. What order do I use the clay bar and iron remover? Do I clay first, and then use the iron remover, or is it better to use the iron remover first?
2) After I use, the iron remover, is it sufficient to just rinse it off thoroughly with water, or do I need to wash the car again with soap or a rinseless wash?
Thank you,
Joe
Re: First time using Iron Remover, a couple questions
You're doing a great step to help decontaminate your paint. I use an iron remover after i wash the vehicle but before claying.
My thought on the order of steps is that I don't want to pick up any ferrous metal pieces in my clay and work that around the paint. I like removing "iron" first, then clay.
I apply my iron product all over the paint with a pressurized spray bottle. Give it time to dissolve what it finds then simply, and thoroughly, rinse off. Don't let it dry before rinsing.
I don't wash again after fully rinsing it off.
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
^^Solid info here. I do similar. Wash, iron remover, clay, wash.
Scott Harle
Autodermatology
#autodermatology
Post Thanks / Like - 2 Thanks, 2 Likes, 0 Dislikes
I wash, rinse, spray iron remover, let dwell, clay mitt with soap, then final rinse. Essentially I use the IR and soapy clay mitt for as a one step ish
As mentioned, ideally you want the wash process and iron removing steps done prior to a clay product. This removes as much contamination as possible prior to rubbing on the paint.
I do this -
1/Decon wash and rinse (Carpro Lift or Descale)
2/Apply an iron remover and allow to dwell
3/Thorough rinse (I have in the past re-foamed the car and then rinsed)
4/While still wet, I clay with Megs M34 for lubricant.
5/Either rinse again and dry, or just dry.
There are also combination iron remover/clay lubricants that combine those two steps into one. I have them but prefer the two-step procedure. Think Carpro Immolube, Megs Iron-Removing-Clay-Spray or NV Purify. Likewise, you can use your iron-remover as the clay lubricant, again I prefer the two step method.
The aforementioned info is great info. Just FYI some color changing wheel cleaner works great on paint some doesn’t.
I’ve read awd several wheel cleaners and paint Decon’s, Iron X and Griots iron remover to mention a couple.
I’ve switch to BlackFire Iron remover. Works as well as the other two I’ve mentioned but can be applied to a dirty car and can be used on a dirty car.
This allows me to apply before initial decon wash.
Spray BFIR, let dwell. Rinse. Decon wash. Clay and then rinse and dry.
Thanks for the product suggestions. Have you tried the relatively new Turtle Wax Wheel Cleaner and Iron Remover? It is supposed to have some sort of scent-blocking technology so that it doesn't smell quite as bad as other iron removers. But of course I would want to use it only if it actually does a good job of removing the iron particles.
It smells like an elephant exhibit at the zoo and the smell lingers, works very well on wheels I never tried it on paint
I will say that the TW product dries relatively quickly compared to others I’ve used, I’d recommend doing 1 panel at first to see if you experience the same
I have not but I don’t have the best sense of smell so even Iron X just smells like farts
By joebruin77 in forum Auto Detailing 101
Last Post: 01-10-2022, 10:42 AM
By paulsiu in forum Auto Detailing 101
Last Post: 09-04-2019, 08:29 AM
By ejaf in forum Auto Detailing 101
Last Post: 06-06-2019, 12:36 PM
By Swift in forum Off-Topic
Last Post: 01-19-2018, 09:23 AM
By StalkerStang in forum Auto Detailing 101
Last Post: 03-29-2015, 01:43 PM
