Have you tried a decent steam cleaner.
I tend to find this worked on my wife's 2006 powder blue seats
Re: Can my cloth seats be salvaged?
I removed the seats. The factory seat covers were quite easy to remove and replace. I took them off and sprayed them with some APC and hosed them off. Let them dry up and reinstalled. They are snapped on. You should take a look at yours
Unfortunately, the seat covers on my seat aren't very easy to remove. Mainly due to the airbag device and associated wiring. I've taken this car apart more times than I can count for stereo related things and I once attempted to do some seat work and wound up scrapping the idea due to this. I mean, I could do it... but I wouldn't call it easy.
All I did was spray my wife's car seats with 303 cleaner and scrub with a cheap medium strength tooth brush. Rub with a microfibre and let it dry.
When that left rings like water stains I grabbed my karcher steamer that I use for cleaning ovens, showers and tiles.
I used the floor cleaner with a white terry towel and took my time and to do front and back seats took me about an hour but looked new!
I then sprayed them with 303 protector and left to dry over night and the finish was brilliant
Since I don't have a steamer, if I was tackling this job I would start with a good fabric cleaner like CG Fabric Clean. Mist the seats lightly with distilled water, mist with CGFC, then use an upholstery brush to scrub lightly. Then use a household extractor like a little green machine with only water in the soap dispenser. Use the water to rinse as you extract. If the foam of the CG causes problems, you could also try something like Folex which is available at home improvement stores.
2016 Accord EXL V6 w/Navi & Sensing - Black/Ivory
2019 Acura RDX A-Spec - Black/Red; 2019 Acura TLX Base 2.4L - MSM/Black
2008 CRV EX - Black/Black 2003 Accord EX V6 - Black/Tan
I don't have a steam machine myself, but I might be able to borrow one.
By adoomy in forum Auto Detailing 101
Last Post: 11-27-2016, 02:48 AM
By CaneCharger in forum Auto Detailing 101
Last Post: 06-11-2012, 11:33 PM
Last Post: 03-16-2012, 02:42 PM
By driverman1 in forum Auto Detailing 101
Last Post: 05-04-2010, 08:40 PM
By LincolnZephyr2006 in forum Auto Detailing 101
Last Post: 01-05-2010, 01:03 PM
