Wet/Damp Sanding & Buffing new paint job recommendations, please...
Mike—
Getting close to color-sanding and buffing my newly painted ’73 Corvette… Painted with PPG DBC Black (base coat) and PPG 2021 (clear coat)…
Plan on using 1000 & 1500 grit hand, then moving to Trizact 3000 and 5000 using a 3m 20235 DA…
Now for buffing, I have both a Makita 9772 rotary and PC 7424, but I am not planning on using the PC, just using the Makita exclusively…
I was planning on using the 3M Perfect-it products for pads/compounds/polish… Here is the list/steps of what I’m thinking about using:
1) 3M 33279 Wool Pad/05706 White Foam Pad with 06085 Compound
2) 3M 05707 Black Foam Pad with 06064 Polish
3) 3M 05708 Blue Foam Pad with 06068 Ultra Polish
Questions:
Q1: Can I skip the wool pad and just go foam??? Pros/cons???
Q2: For steps 2/3 above, is the PC better than the Makita, or stick with Makita???
Q3: If I don’t use 3M products, what would you recommend???
Q4: Any issues jumping from 1500 to 3000 when wet/damp sanding??
Thanks much…
Rogman
Re: Wet/Damp Sanding & Buffing new paint job recommendations, please...
Sounds like a fun project, I really like the 1973 Corvette body styles...
What color did you paint it?
Originally Posted by rogman16
Questions:
Historically, wool cutting pads tend to cut cooler and faster than foam cutting pads. Personal preference but be sure to monitor surface temperature anytime you're compounding with either pad. I did this constantly for the Nebraska AMX project
1969 AMX Wetsanding Videos - Nebraska Help in the Heartland Project
Using the method I write about here,
Fight or Flight Method for Gaging Surface Temperature
Personal preference based upon your "opinion", "experience" and skills. You can start World War III over the topic of using only a rotary buffer to finish out hologram free.
3M makes great products, kind of sounds like you've done this before so if you're comfortable with 3M then stick with them...
Thanks much…
Rogman
There can be. The goal is to refine the depth of your sanding marks, that is to turn the depth of #1500 grit sanding marks into the depth of #3000 grit sanding marks and to do this you need to focus on the task at hand.
Probably the most important thing is to really do a good job of finishing out with the #3000 to ensure you've leveled the deeper #1500 scratches are you'll be fighting them during the compounding step.
Top Coat Hardness = Unknown Variable
The unknown factor that affects much of what you're going to attempt to do is the top coat hardness and the hardness of the paint, even a brand new paint job can and will affect how easy or how difficult it will be to both sand and buff the paint.
I try very hard to practice what I preach and this means doing a Test Spot on everything I buff out INCLUDING any wetsanding projects.
Fast forward in this FIRST video from the AMX wetsanding project to the 8:12 Time Mark and you can watch as I explain WHY we're going to do a test spot that includes all the steps of sanding, compounding and polishing the paint BEFORE we sand down the entire car.
1969 AMX - Wetsanding How To Video - Part 1 - 30 Minutes
You can of course just dive in head first and sand down the entire car before you do any testing to dial in your "system" for removing your sanding marks, that's completely up to you.
I for one like to test first, and then move forward...
Is this your project?
Looks like a real sweet project...
How many coats of clear did you spray?
Yepper, that is me Mike!!! I am in Las Vegas, NV... Actually the car is in Las Vegas and I'm stationed (active duty Air Force) in D.C. going to school for a year...
Color is black with three coats of chemically hardened urethane clear...
I have done this before, but was 25+ years ago when we sprayed laquer on all our corvette projects, and all we ever used at that time was wool buffer, compound and liquid ebony to finish up... So, I'm not stuck on 3m and just looking to capitalize on all the effectiveness and efficiency of the newer technology...
You have a great site here and I literally spent all weekend watching your videos and reading many posts... Right now, I'm leaning toward first buff after 5000 finishing sand will be wool with compound on the rotary... After sanding scratches are removed, will move to foam on PC to do last two steps of polish/seal...
Guessing either Meguiar's, Menzerna, Pinnacle for last two steps with CCS pads on the PC...
Thanks for your replies... I need to go watch the videos you sent me...
Rogman
Very cool project... what size engine is she going to have?
Sounds good. Every painter is different in their style and can spray light or heavy coats so as long as he knows you were going to sand and buff before he sprayed you should have plenty of material to work with...
I have done this before, but was 25+ years ago when we sprayed lacquer on all our corvette projects, and all we ever used at that time was wool buffer, compound and liquid ebony to finish up...
I've done all of the above and I'm glad to say there's very good products out for this today...
So, I'm not stuck on 3M and just looking to capitalize on all the effectiveness and efficiency of the newer technology...
3M is primarily knows as an abrasive company although they branch out into all markets with quality products. Their sandpapers, sanding discs, compounds and polishes are all top notch.
I'm not sure off hand if they make any polishes specifically designed and formulated for use with a dual action polisher. All of the pro products state on the label to use with a rotary buffer. I'll check with our 3M Rep as we're in communications for the upcoming Mustang project.
Thank you. A good forum is both helpful and friendly, a person shouldn't have to fear getting into a flame war or seeking out so we do our best to run a professional forum here...
That's how I would approach it. Even if you finish out at #3000 or #5000 grit the sanding marks are going to buff out fastest and more completely using wool pads and a compound. This job already takes a long time there's no need to make it take any longer using a less aggressive approach.
I would actually stick with the rotary buffer for the first polishing step with a foam polishing pad and a foam pad polish. This is to make sure you remove any swirls left by the compound abrasives and the fibers of the wool cutting pad. How easy or difficult it is to remove these depends upon a lot of things including how hard you're pushing down on the rotary buffer while making your last passes during the compounding step.
Any of the above for the last machine applied polishing step will ensure a hologram free finish the day you do the polishing and down the road.
Rogman
Keep up updated as I love these types of projects and myself and our forum members will help wherever we can...
Just wanted to chime in and say that I am military on Nellis and work in a body shop if you need any help.
Ding Dang!
I'd take Mike up on his offer, he's up to date with everything we talk about on the forum, he'd be a real asset to the project.
I'm in DC on Andrews if you wanna brush up on your skills. I have plenty of different tools and product to try also. Including meguiars, 3m, and menzerna
Sent from my SAMSUNG-SGH-I777 using AG Online
That's awesome guys... I'm flying back home (to Las Vegas) this Saturday... Plan is to get paint and clear (plus cut and buffed) on at least half of the car while I'm home...
My 2 biggest hurdles to this are:
1) Getting car and garage up to above 60 degrees when I plan to shoot... I'm going to insulate my garage door and figure a good way to get some heat in there...
2) Need to either buy or rent a bigger compressor... Don't have any 240V plugs in the garage, and my breaker box is completely full... So I either need to daisy chain two 115V compressors together (which is dangerous and what I really don't want to do) or get a gas powered air compressor...
Any suggestions would be appreciated...
Thanks much
Rogman
Last Post: 06-20-2017, 08:38 AM
By KB in MD in forum Wet-Sanding, Cutting & Buffing
Last Post: 12-16-2014, 06:37 AM
By Jeepster19 in forum Ask your detailing questions!
Last Post: 11-20-2013, 02:20 PM
By adrynalinjunkie in forum Ask your detailing questions!
Last Post: 01-06-2013, 07:58 AM
By Steampunk in forum Wet-Sanding, Cutting & Buffing
Last Post: 11-20-2010, 04:56 PM
