3 inch Backing Plate & PC 7424
When using a 3 inch Backing Plate & PC 7424. Is it paramount to remove the 5 inch counter weight? Or is it six of 1 half dozen of another?
Re: 3 inch Backing Plate & PC 7424
No need to remove it, also need need to exchange it with any other cw. I've used mine w/ both 4" and 5.5" pads for years with the cw that came with the pc.
Mine runs fine with 3 or 4 in BP/Pads and original counter weight.
Kevin
That's what I figured. The counterweight has a warning on there, which makes you pause for thought.
The counterweight might make a difference with a thin sanding disk, but doesn't seem to make a difference with a foam pad.
What about Meguiars DA system cutting discs? Thicker than a sanding disc, but thinner than a foam pad.
I just did 2 cars with the DA MF 5 in pads on my GG 6 in and 3 in pads on my 7424. Absolutley no problem.
Kevin
Did the edges of the backing plate stick out?
What do you mean? Over the pad, no. I could see the counterweight. The BP and pad looked really small for the polisher. I did quite a bit of the smaller areas with the 3 in pads. I am using the bp from my GG 3 in polisher.
Kevin
What do you guys make of this, any body have a scale to tell us the weight?
Porter-Cable 7424XP Counterweight Facts
Last Post: 10-07-2021, 02:58 PM
By Whipped500 in forum Griot’s Garage Polishers - BOSS - 6" DA - 3" DA
Last Post: 01-22-2018, 09:45 AM
By Witty4242 in forum Product Reviews
Last Post: 02-16-2014, 11:49 AM
By Fishincricket in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-28-2013, 10:39 AM
By FlawlessMustang in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 08-17-2012, 04:30 PM
