Re: Rotary Buffer Circle Scratches - Why to use a Pad Cleaning Spur or Nylon Brush
Good reminder that things happen to the best of us. Good thing it was a demo hood!
Perfection is attained by slow degrees; it requires the hand of time. (Voltaire)
2013 TESLA MODEL S | Gyeon Syncro | Gyeon Cancoat
No doubt...
And... I did spur the heck out of my pad.
This same thing happen to me a LONG time ago with a foam pad on a black BMW - painful lesson...
No doubt about that...
I had no fear to machine sand with #3000 till the circle scratches were gone and then compound.
Which would be better compressed air to clean wool or the spur?
I am getting ready to start practicing on paint perfection with the rotary.
Detailing is a way of life, not a hobby!
Nice tips, Mike.
What about the "cheese grater" part of the Duo-Spur by Lake Country? Can't say I've ever seen anyone using that. Do you have any pics in your massive Library of Detailing?
Good information.
Mike, how often do those demo hoods have to be repainted from all the testing?
Both if you have them...
Originally Posted by WRAPT C5Z06
Good information.
The one you see in the picture is off a Fox Body Mustang, it is the most perfect demo hood due to its size. Keep in mind, we ship this demo hood to Las Vegas for SEMA every year and large bulky hoods are difficult to ship.
As for how often I get it re-sprayed? My buddy Paul Grasso down at Grasso Garage squirts them for $200.00 using the PPG Global Paint System and I have this one sprayed about 3 times a year.
Originally Posted by JustJesus
Nice tips, Mike.
I never use that tool for cleaning pads... the first and last time I tried it I wasn't sure it was better or more effective than using the normal nylon pad cleaning brush on foam pads. YOu wouldn't use the cheese grater side for wool pads, just foam pads.
I could try it again and get back to you.
I use to own a "Refinisher".
This was a foam pad cleaning and resurfacing table-top or wall-mounted device developed by John Kosmoski of House of Kolor. He sent Meguiar's a sample to see if Meguiar's wanted to carry it and Meguiar's didn't want to carry it so I took it home.
It had a large stainless still top, kind of like shelf or thin table made of stainless steel. in the middle was a stainless steel cheese grater kind of structure. What you would do is place your worn foam pad on a rotary buffer and holding the pad flat on the table, run it back and forth over the grater part and it would shred of a layer of foam.
Back then all we had was THICK and LARGE foam pads so it would work for pads like these. But if you ran a ThinPro pad over it you'd probably be down to the velcro on the backing plate after a pass or two.
I know longer have it as it was large, bulky and heavy. I wish I would have kept it since it was from John Kosmoski.
http://www.houseofkolor.com/company/?ref=topnav
More car detailing history only here on AGO - where else would you ever read about this kind of stuff?
I used to use a large screwdriver.
I absolutely DO NOT recommend that technique.
Toothbrushes were what I used on the foam pads - but that was a LONG time ago. I have a few pad conditioning brushes lying around these days.
I have one, but kind of forget about it since it's off to the side. Out of sight....
I guess I can try it too
That's what I thought the Duo-Spur (cheese grater part) was for as well. To "reshape" the thick foam pad back into shape. I figured it would remove some foam in the process. haha..Today's thin foam pads? No way!
That would have been kool. hehe.. . Wasn't John K one of the first advocates for water-based paint systems?
Nowhere! Love reading the history bits
edit: I may have been confusing water-based paint for his base coat/clear coat usage
Last Post: 02-03-2019, 12:30 AM
By Milwaukeedetail in forum Ask your detailing questions!
Last Post: 05-09-2013, 11:44 AM
By bigaizsosexy in forum Off-Topic
Last Post: 02-28-2012, 12:15 PM
By Lonewolf2007 in forum Ask your detailing questions!
Last Post: 04-20-2010, 05:26 PM
