Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Apr 2006
    York, PA / CocoaBeach, FL
    42
    Wax/sealant removal on matte finish wheels
    I got a new set of Work CR Ultimate's in matte bronze last spring. I promptly added 2 layers of OLD Poorboys wheel sealant so I think maybe that be a part of the problem to begin with. I think I purchased it back in 2005/6. I could never quite buff off all out before i ended up getting the tires installed and mounted the wheels on the car. I figured I'd tackle it before spring hit the next year. Fast forward to now, I grabbed a wheel and threw it in the tub and started scrubbing it down with Dawn and an MF rag. Yet, the wax continues to prevail. I dried the wheel and then followed it up with another MF rag with 91% isopropyl rubbing alcohol. This kind of works. You still need to give it some elbow grease and requires a lot of scrubbing. The barrel of the wheel is worse where the sealant is sitting in machining lines.
    I need some advice here to get this crap out of the finish without hurting the finish at all. Please help!
    Pics for clicks:
    Wax/sealant removal on matte finish wheels-img_20160410_150854-jpg
    Wax/sealant removal on matte finish wheels-img_20160910_121756-jpg
    Re: Wax/sealant removal on matte finish wheels
    Nice wheels...
    I've been impressed with this product for removing old dried wax and sealant...
    Try the little bottle and if it works there's a larger size...
    McKee's 37 Wax Remover for Plastic removes dried on wax from plastic rubber vinyl trim
    McKee's 37 Wax Remover for Plastic 16 oz.
    Besides that experimentation is the only option...
    SELF BANNED
    Jun 2012
    80
    Acetone on the barrels will make quick work of removing all that Wax.
    Just use a little on a rag and wipe quickly do not let it sit or pour it on the rim.
    Super Member Hammer77's Avatar
    Aug 2015
    Adrian, Michigan
    1,043
    Nice wheels. But damn that blue on the car really looks great, sweet looking ride!
    Apr 2006
    42
    Nice wheels...
    Thank you and awesome, I'll look into that. Thanks Mike!
    Quote Originally Posted by Dave.0 View Post
    I'd be afraid to use acetone on these wheels. They weren't exactly cheap.
    Quote Originally Posted by Hammer77 View Post
    Thanks man! The picture kind've sucks...a bit too dark.
    SELF BANNED
    Jun 2012
    80
    " I'd be afraid to use acetone on these wheels. They weren't exactly cheap."
    I have used Acetone on $1,000.00 per rim HRE wheels it will not hurt them.
    Remember it just wiping down the barrels to strip off old sealant and wax NOT soaking them in Acetone.
    Jan 2015
    Simi Valley, CA
    1,783
    I too would be very careful with acetone. I'm not saying that I wouldn't do it but I'd certainly be very cautious. There are less aggressive solvents that I'd try first... I'd recommend solvents in this order (least aggressive to most aggressive) - Mineral Spirits/Paint Thinner, Enamel Reducer, Lacquer Thinner, Acetone.
    Just like paint correction, a "best practice" is to always use the least aggressive process that will give the results you desire. Additionally, a test spot would also be in my plan.
    In the OP's case, I see starting with acetone akin to cleaning chrome with steel wool... Both of which would make me cringe.
    Apr 2006
    42
    Quote Originally Posted by 2black1s View Post
    these all sound scary, lol
    SELF BANNED
    Jun 2012
    80
    Ok then if your scared buy a dog to protect you. lol
    Step up or start rubbing your wheels down for 3 months with 91% isopropyl rubbing alcohol.
    I use the most effective product first and I am giving you my tested advice first. I have done this on factory wheels, HRE, BBS, 949 and many others.
    Use a small test spot and you will see.
    I am not telling you to soak the towel or rim in Acetone. Just put a little on a rang and test a small section on the inside of the barrel.
  10. #10
    Jan 2015
    Simi Valley, CA
    1,783
    Quote Originally Posted by n7plus1 View Post
    Mineral Spirits is actually pretty benign and an excellent all-around de-greaser/cleaner.
  1. What do you use for matte finish LSP?
    By choijw2 in forum Auto Detailing 101
    Last Post: 10-20-2016, 03:17 PM
  2. Best Coating or Sealant for Matte Ballaxk wheels
    By Pats300zx in forum Auto Detailing 101
    Last Post: 04-27-2016, 09:01 PM
  3. Tires Matte Finish
    By Ricorocks in forum Auto Detailing 101
    Last Post: 09-22-2015, 08:03 AM
  4. Can you use meticulous matte on a non-Matte if finish?
    By mets2010 in forum Auto Detailing 101
    Last Post: 04-08-2013, 11:50 PM
  5. What sealant/wax for matte paint finish?
    By Kaban in forum Auto Detailing 101
    Last Post: 10-13-2012, 02:24 PM
