Results 11 to 20 of 21
    Jan 2015
    Simi Valley, CA
    1,783
    Re: New windshield has some time of oily film
    I'm not a professional so I'll leave it to you to decide the merit, or lack thereof, of my method, but nonetheless, here's what I would do.
    Start by scrubbing the windshield with a terry towel/rag saturated, but not dripping, with mineral spirits. Allow the mineral spirits to dwell for a few minutes then scrub again. Finish this step by wiping with a clean terry towel. If you want to, you can use 0000 steel wool during this step - That's your call.
    Then repeat the process except use Isopropyl Alcohol for this step. The Isopropyl Alcohol will evaporate much quicker than the mineral spirits so adjust your process accordingly. Regardless of whether or not you used steel wool in the previous step, do not use it for this step or beyond.
    Assess the results. You may be finished at this point. If not, then follow-up with clay and/or compound and re-assess.
    Obviously, you want to clean any residues following each of these steps. Use whatever method you like. For the very final step, apply a glass treatment of your choice.
    If the windshield isn't clean at this point then you can either repeat any, or all, of these steps until it is clean, you can just say F it and do your best to live with it, or go back to glass shop and see if they can fix or replace it.
    Good Luck.
    Super Member emmjay's Avatar
    Feb 2015
    Dubai, U.A.E
    848
    Alright guys thanks for all the replies.
    To be honest steel wool on anything scares me. I don't think i've ever used it on anything my whole life.
    Secondly, the windshield is brand new installed by the local vw dealer (we only have 1 in Dubai), even the wiper blades are genuine VW. I told them at the dealer that this problem is happening and they said they have no heard of such a thing before. Did not bother going back as its a waste of time.
    I never had this problem for two years on my previous windshield and have never seen it on my previous VW nor on any other cars in the house.
    I think, I will be trying one of the polishes on my glass - m205 with the orange hybrids as they are the most aggressive.
    Would that work? Or should I go most aggressive with UC? I can only use what I have - I cannot order anything from AGO at this point.
    Would need this done soon as its the start of winter here, which means more rain.
    Thanks
  3. #13
    Super Member builthatch's Avatar
    May 2008
    east coast
    2,352
    0000 steel wool on glass...with glass cleaner...is exactly what is done at the local McLaren/Porsche dealer to clean windshields. sure, dealers can be home to some of the most treacherous detailing stuff ever seen, but these guys found a fine line between common volume detailing techniques and the overkill "boutique" detailing techniques we dwell on. they did it under my watch prior to Opti-Glass installation and no issues were detected under close scrutiny.
    all glass is not created equal, i will admit that. and technique/product can be a very influential combo. still, 0000 steel wool is very commonly used for this purpose.
    OP, if it were me and i encountered this, i would first clean with Power Clean at full strength because that would most likely dissolve/dilute/lift any oily contamination, making sure to keep the entire area wet the entire time (misting water is fine), wash it all off, rinse VERY well then assess, then if it's still an issue, Hyper polish on a no cut/low cut pad and go over the whole thing, wipe and assess. i would also clean the wiper blades extremely well, over and over with Power Clean and an old MF, until NO black comes off.
  4. #14
    Feb 2015
    Dubai, U.A.E
    848
    Guys you have been awesome but I must add, I can only use what I have at hand. These products are:
    1. Meguiars APC (is this like powerclean?)
    2. Meguairs m205, UP , Swirlx and UC
    3. Sonax Nano Polish 3/6
    4. Flex 3401 - hybrid pad range orange, white and black
    Thats it...
    I'm still new to all this - Would I have to saturate a towel in the APC and just wipe the glass by working it in?
    I did use some straight up IPA 70% on my wiper blades last night and it removed extremely black stuff, and I tried the wipers again, it was definitely better but not great.
    My windshield still has a film of water on it rather than sheeting/rolling off. So i feel it might just be a combination of the wiper blades AND something on the glass.
  5. #15
    May 2008
    east coast
    2,352
    Quote Originally Posted by emmjaygti View Post
    Thats it...
    yeah i'm sure you can use that APC, i just don't know a dilution that's ideal. if i recall, it's somewhat more alkaline than Power Clean so you might want to try 1:1 with water, let it dwell but don't let it dry. someone with specific experience with that APC might want to chime in.
    then for the polish part, white or even black pad with UP or M205 should do the trick - that's what i'd try if the APC thing didn't do the trick. glass is very hard so you won't hurt it with that, but it should be enough to remove whatever is leftover after the APC wash.
  6. #16
    Feb 2015
    Dubai, U.A.E
    848
    Alright a little update, I went out to the car, sprayed direct APC on to the glass with a terry cloth towel and scrubbed the glass. Rinsed the glass a few times and the film-ing was a lot worse. Now the water would not even move.
    I also used direct apc on the wiper blades a few times, and also used ipa a few times. The result was still a little black residue.
    New windshield has some time of oily film-img_7550-jpg
    New windshield has some time of oily film-img_7552-jpg
    New windshield has some time of oily film-img_7555-jpg
    I then sprayed the glass with a ipa solution and wiped clean and tried Ultimate compound with as much pressure as I could using the LC EZ grip blue cutting pads.
    Tried a few passes each with max pressure applied, wiped off UC, sprayed a little IPA and wiped again to a clear glass.
    I then sprayed with water to see what would happen.....still the same.... I used a glass blade wiper thing to show the difference.
    Left side is wiped off, right side is a film of water...
    New windshield has some time of oily film-img_7558-jpg
    After this I tried the wipers again, there was a slight chatter and the same result as yesterday with just smearing of water and the water being pushed around rather than wiping.
    Maybe I need to try with the flex? That would be in a few days when I actually have the time. Currently everyone is asleep and the flex is bloody loud.
    Attached Thumbnails Attached Thumbnails New windshield has some time of oily film-img_7554-jpg
  7. #17
    Super Member conman1395's Avatar
    Nov 2013
    Kansas City, KS
    1,622
    Thats it...
    Meguiars APC at 10:1 first (that's the interior dilution) and if you must, then 4:1.
    2017 Infiniti Q60 3.0t AWD
  8. #18
    Feb 2015
    Dubai, U.A.E
    848
    I went out for a drive as the streets are quite clear at this time.
    I used the wiper and windshield washer fluid and it did seem a little better, with a little bit of chatter from the blades. It wiped off but still left some film on the glass but at least a 60% improvement from before.
    The liquid being sprayed from the windshield nozzle jets is quite soapy, i was wondering could this be a problem? Maybe the dealer decided to put some crap in there that leaves behind a film too?
    Before, I only used to add water to the washer jets and that would clean quite well.
    After all this I wonder, maybe the wiper blades are just bad? We don't get bosch aerotwins here otherwise I would get those, we only get the oem vw ones from the dealer. Maybe I can try another set....a bit pricey but with rain coming up its not worth risking it.
  9. #19
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    DP Glass Restorer ...
    Scott
  10. #20
    Sep 2009
    53
    Apply Rain X.
  1. Help!! Oily Black Splatters all the time!
    By tman95 in forum Auto Detailing 101
    Last Post: 10-10-2019, 06:35 AM
  2. Seemingly oily substance of windshield.
    By CrossfireLTD in forum Ask your detailing questions!
    Last Post: 12-24-2018, 06:40 AM
  3. Need some help..weird windshield film
    By BTLew81 in forum Auto Detailing 101
    Last Post: 01-27-2016, 08:40 AM
  4. New windshield film/residue
    By drewberg11 in forum Auto Detailing 101
    Last Post: 09-30-2013, 06:27 PM
  5. Film on windshield after cleaning
    By DrMcDave in forum Auto Detailing 101
    Last Post: 01-04-2011, 04:56 PM
