Klasse AIO & Porter Cable to Remove Light Swirls
Hi,
Is it possible to remove light swirls using Klasse AIO with wax pad on Porter Cable?
Trying to use least aggressive approach.
If not, how about use Klasse AIO with polishing pad? Bad idea?
Thanks!
Re: Klasse AIO & Porter Cable to Remove Light Swirls
You can use AIO with a polishing pad, it will clean the paint well, whatever correction you get will be minimal.
No abrasives in the AIO, you'll be getting some cut if you use a cut pad, but product makes the pad for sure...it cleans really well though! I do my fiberglass exterior doors on my house with this because it cleans them and seals them...IMO.
Agree.
Klasse AIO is a chemical cleaner with some sealant. There is nothing abrasive in the product. Even with a polishing pad I'd be surprised if you could get any noticeable correction. I really doubt you'll be able to remove even light swirls.
Just get a true fine cut polish. The amount of paint removed is minimal and the process will perfect your car's paint.
Then wash, dry or anytime you wipe or touch the paint do so as carefully as you can to avoid future scratches.
Here's an example, the Wolfgang Finishing Glaze isn't a glaze but a fine cut polish.
The Wolfgang Four
Here are four products that will take care of about 99.9% of any exterior paint correction product you'll ever have in your garage.
The Wolfgang Four
Forum member RFulmer coined this term, (due credit where credit is due), and since there's been a lot of questions about what each product is, what they do, the order of aggressiveness and when you use one over the other, here's some info...
Uber Compound
- Aggressive Compound - More aggressive than Wolfgang Total Swirl Remover and Wolfgang Finishing Glaze.
- For use with any type of polisher/buffer and can be used by hand.
- Body Shop Safe = Can be used in a fresh paint. environment (body shop) and can be used on fresh paint, (paint just sprayed and less than 30 days old).
- Safe for Ceramiclear paints.
- Cafe for all clear coat paints.
- Safe for all single stage paints.
- For some people on some cars it can be used as a compound/polish after which the paint can be sealed with a wax or synthetic paint sealant.
Total Swirl Remover
- Medium Cut Polish - Less aggressive than Uber Compound and more aggressive than Wolfgang Finishing Glaze.
- Should be tested before using Uber Compound to see if it will remove defects to our satisfaction in keeping with the practice of using the least aggressive product to get the job done.
Finishing Glaze
- Fine Cut Polish - Much less aggressive than Wolfgang Total Swirl Remover and of course dramatically less aggressive than Wolfgang Uber Compound.
- Should be tested before using Wolfgang Total Swirl Remover to see if it will remove defects to our satisfaction in keeping with the practice of using the least aggressive product to get the job done.
- Great "Maintenance Polish" for use removing shallow swirls that show up over time from normal wear-n-tear on daily drivers and after a person has already performed a multi-step procedure to remove serious paint defects.
Deep Gloss Paint Sealant 3.0
- German engineered synthetic paint sealant.
- Non-cleaning, pure synthetic - Paint must be in excellent condition as in brand new or previously polished to like new condition before use.
- Can be applied by hand or any type of dual action polisher wit foam pads.
- This product "seals" the paint in the say way a car wax or paint coating will seal the paint. It is water insoluble and as such like all synthetic paint sealants, car waxes and paint coatings is not body shop safe.
- Requires 30 to 45 minutes of drying time before removal.
- Oxygen activated. After buffing off the excess sealant the remaining protection ingredients should be allowed to cure and fully set-up for an approximate 12 hour window of time before the vehicle is put back into service where it will be exposed to water.
Synergistic Chemical Compatibility
Each product is chemically compatible and chemically beneficial when used as a system approach to take a diamond in the rough and turn it into a glistening gemstone. Using the entire line in the correct order or just a few of the product in the correct order is an example of working forward in the paint polishing process.
All Inclusive System-Approach
This group of four products with just about any tool, any pad and even by hand will produce not only show car results but do it consistently across a VERY wide spectrum of paint systems including,
- Hard paints, soft paints and everything in-between.
- Factory OEM paints and aftermarket repaints at your local body shop or custom paint shop.
- Single stage and basecoat clearcoat.
Which products do you need?
Which product you'll need depend upon the condition of the paint on the car. Click to my list of paint condition categories and read through the descriptions for the different categories. Then after washing and drying your car, inspect the paint both with your sense of touch, (The Baggie Test), and visually with your eyes in bright light for swirls and scratches.
Then determine which category your car's paint fall into. Here are some general guidelines but the best way to determine which exact product you'll need to remove the defects and restore the finish on your car to your expectations can only be determined by doing a Test Spot
How To Do a Test Spot
Test Spot results showing the before and after difference...
On Autogeek.net
Wolfgang Uber Compound 3.0
Total Swirl Remover
Finishing Glaze
And if you don't have a 5" backing plate and 5.5" pads get them...
5 inch Backing Plates on Meguiar's, Griot's and Porter Cable DA Polishers
__________________
The Wolfgang Four
The Wolfgang Four
Uber Compound
Total Swirl Remover
Finishing Glaze
__________________
I actually told Mike to send this to you....we go way back. He passes on all the stuff we talk about....
phhhhhhhhhhhhhhhhhhhhhhhhhh!!!!! hahahaha!
Thank you all so much for the guidance!
Can I ask, what is your opinion on the Wolfgang paint sealant 3.0 vs Pinnacle Black Diamond Sealant.
My car is black.
I also plan to follow with pinnacle souveran wax.
Thanks again!
This very topic came up today. Hopefully this will help.
http://www.autogeekonline.net/forum/...d-sealant.html
Originally Posted by Desertnate
Yeah, it came up today because it's the same member asking the question in both cases.
By Honais in forum Auto Detailing 101
Last Post: 11-16-2015, 04:31 PM
By starjammir in forum Auto Detailing 101
Last Post: 08-09-2011, 01:10 PM
By jonn127 in forum Auto Detailing 101
Last Post: 01-10-2011, 12:04 PM
By Mike Phillips in forum Autogeek on Velocity Channel TV
Last Post: 05-11-2010, 12:38 PM
By Mr.Clean3000 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 02-25-2008, 08:00 AM
