Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jan 2015
    Question Does Polish Clean Like Cleaner Wax?
    Most waxes seem to be cleaner waxes. And I like cleaner wax because most of the old cars I buy have ground in dirt that mere washing does not get out. The cleaner wax gets a lot of that dirt out.
    I have been reading that synthetic polish lasts longer than wax, so I would like to use it for that, but will polish clean the ground in dirt like (cleaner) wax does?
    May 2010
    Colorado Springs, CO
    466
    Re: Does Polish Clean Like Cleaner Wax?
    Quote Originally Posted by TomBrooklyn View Post
    Sounds like this is the perfect product for what you want to accomplish: Wolfgang Uber All In One, cleaner wax, all in one polish wax
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Cleaner waxes work using chemicals and sometimes mild abrasives to remove stains and very minor paint defects. Some have very good filling abilities as well.
    You say "synthetic polish", but the term polish isn't used much now. It has been replaced by LSP, Last Step Product.
    Finish waxes and Sealants typically do not remove staining, oxidation of water spots like a Cleaner Wax can.
    Here is a good starting point:
    Car Wax, paint Sealants,Car Waxes, Show Car Wax, Best Car Wax, Carnauba Car wax, P21s Car wax, Pinnacle Souveran Wax, Meguiars car wax, Mothers
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    Lots of confusion in the naming of car-care products.
    For example:
    -There is at least one Company that designates
    their polishes as being paint cleaners.
    -Glazes...what in the dickins is a Glaze?
    Good Luck in finding a universally accepted definition!
    IMHO:
    Here's a couple of excellent MP articles that sorts-out some of the confusion:
    http://www.autogeekonline.net/forum/...ers-waxes.html
    http://www.autogeekonline.net/forum/...shing-wax.html
    Super Member Bunky's Avatar
    Jun 2007
    Hillsborough, NC
    6,201
    The cleaning ability of cleaner/wax products varies. The best approach is to use a separate paint cleaner then wax/sealant to get the best results but you can also use a cleaner/wax stronger in cleaning and add another layer of wax (something with less cleaners) to improve the protection.
    For example, if you were using Blackfire products, you could use Total Polish and Seal to clean/protect then top with Wet Diamonds for added protection.
    Al
    The Need to Bead
    Jan 2015
    Thumbs up Re: Does Polish Clean Like Cleaner Wax?
    Thanks to all for the suggestions so far. I will check out all that suggesting reading soon.
    Quote Originally Posted by jsgntulok View Post
    I read this link so far, and that product does sound like it has both the cleaning and long lasting properties I'd like to combine.
    Feb 2012
    Ireland
    1,149
    Waxes, which you buy in pots, are paste waxes. They are pretty much solid lumps. These are NOT cleaner waxes.
    Waxes - which are liquid creams, are actually water containing products, will mostly be cleaner waxes.
    Do NOT mix these two.
    I have explained elsewhere that the base for a liquid product is going to be what many people seem to call a pre-wax cleanser. Almost all the other liquid products will be this PLUS something else. So, for instance, a cleaner wax will be a pre-wax cleaner which has wax added. A basic polish will be a pre-wax cleaner with abrasive added. A compound will be the same but with more aggressive abrasives. An all in one can have wax AND abrasive. They are all the same family.
    So, in answer to the question, a 'polish' will almost certainly have the same cleaning capabilities as your cleaner wax or a pre-wax cleaner.
    Super Member Audios S6's Avatar
    Oct 2011
    Shoreview, MN
    1,634
    It should be noted that if you are currently using a cleaner wax that is liquid, then you are using a synthetic product.
    Since terminology isn't standardized, it's important to understand what the product is actually doing.
    All the below products are All-in-One type products:
    Duragloss Total Performance Polish
    Wolfgang Uber All-in-one
    Meguiars #6 cleaner wax
    Collonite Sapphire auto wax
    Griots One-step sealant
    1/5 are actually named all-in-one, the rest could easily be confused with a different type of product.
    It sounds like you want to continue using an all-in-one product. If that's the case, which product are you using now? Knowing this we can likely recommend a more durable alternative.
    If you want to step your game up, then use a designated polish before sealing. The polishing step won't take much longer than using a cleaner wax; and sealing should be very fast, so you will spend a little extra time, but get better results from both products.
    Dec 2010
    Ohio, USA
    21,057
    Quote Originally Posted by PiPUK View Post
    ^^^Is this always true?^^^
    For example:
    Meguiar's Cleaner Wax...A-12 (Liquid form):
    Meguiar's Cleaner Wax...A-12 (Paste form):
  10. #10
    Feb 2012
    Ireland
    1,149
    Quote Originally Posted by FUNX725 View Post
    For example:
    I know it is megs but I disagree with them. The question is how the cleaning is done. With a paste type wax, you are using tiny amounts of products. There simply is not enough solvent to do it and there is also the concern as to where the 'dirt' is going.
    Of course the second product could be just a thicker version of the first, not a solid lump of wax... That much I don't know.
    So I'm sticking to my guns here.
  1. Zymol cleaner wax is it a aio or just a cleaner/polish ?
    By wantboost in forum Auto Detailing 101
    Last Post: 05-13-2017, 05:23 PM
  2. I may have used wheel cleaner to clean my carpet? HA!
    By Ohio Detailing in forum Auto Detailing 101
    Last Post: 10-11-2013, 01:33 PM
  3. Clean or Polish
    By galaxy in forum Auto Detailing 101
    Last Post: 08-23-2011, 09:07 AM
  4. FYI: Clean your Universal Pad Cleaner with Orange Cleaner
    By jimmyjam in forum Auto Detailing 101
    Last Post: 11-20-2010, 09:49 AM
  5. Replies: 5
    Last Post: 06-23-2010, 03:11 PM
