Interior Cleaning Issue- Help Please!
As most of you know interior kick panels - on lower door panels, left of driver pedals and of course on door jams are usually soiled.
The interior color is beige and I am afraid of using the wrong cleaner, rubbing to hard and discoloring or causing abrasions on the door or material.
Can you please let me know what you would recommend to clean the panels and keep it clean over time.
Thanks again for your time and input. Autogeek has already received 3 orders based on your prior input on my first question.
Re: Interior Cleaning Issue- Help Please!
Einszett Plastic Deep Cleaner and Cockpit Premium are recommended by many. The problem is they are out of stock right now. I use Meguiar's Quik Interior Detailer. It is a gentle cleaner and mild protectant in one. It provides a nice clean surface without the shine and greasy look. If I come across something that needs a little more muscle I use an APC at an appropriate dilution. Many also rely on steam for dirty interiors.
Welcome to AGO!
For the door jams I would use all purpose cleaner, and use a combination of microfiber towels, and brushes to clean everything then dry, and protect the area with any available sealant but wax would good for the time begin as for the time for the interior a steam cleaner would be helpful but if you don't have one then try an interior cleaner then if that don't work use an all purpose cleaner with a soft brush, and work in small circular sections(wiping the dirty foam away every few seconds) until the area's is to your standard of clean then you can protect it with a trim dressing or leave it
1z deep plastic cleaner nothing works better in my opinion. I've been using for a long time and its the one product I can't be with out.
Thank You all for your input!
By CleanIT in forum Auto Detailing 101
Last Post: 11-01-2020, 11:28 AM
By Maestro Sam in forum Auto Detailing 101
Last Post: 03-13-2019, 06:09 AM
By GirlsAutoKnow in forum Auto Detailing 101
Last Post: 05-16-2017, 03:00 PM
By monty007 in forum Ask your detailing questions!
Last Post: 07-24-2013, 03:31 AM
By tims04gto in forum Ask your detailing questions!
Last Post: 07-07-2011, 07:41 PM
