Re: Rupes Microfiber Cutting Disc with Rupes Zephir Gloss Coarse Gel Compound
It doesn't look like the blue foam pad was fully primed? Is fully priming the pad less important or not needed on this coarse pad or Rupes pads in general?
Wow, Mike... It's amazing you're getting those results from the most aggressive pad and compound! Technology is amazing... Pretty soon you'll get LSP results and remove 1500 grit!
Thanks for doing the test and sharing with us!
I think the Microfiber Pads removed the sanding marks very easily at a low speed and this type of work is normally done with a ROTARY BUFFER.
The aggressive foam cutting pad may have been able to remove the sanding marks but I would have had to use a higher speed setting.
That's one of the greatest insights regarding MF 'vs' Foam Pads questions.
That paint looks incredible from 2 compounding steps. When would we imagine?
Thank you for that,
Kind Regards.
― Isaac Newton
With the Rupes foam pads there is no need to prime, with their MF disc you have to prime, Mike can correct me if I am wrong. Thanks
This is exactly why we switched to all rupes all the time!
The system approach, as before the rupes it was all meguiars, but we just felt that using the products designed for this machine, was the way we should go.
And it's a hard habit to break if you're use to always priming a pad, kind of like a reflex action.
I'd say it's less important with their "system" not so much their pads in general and not needed at all with a pad this coarse.
Because the cells are so large and open in the cell structure of their blue cutting pad and because the foam formula itself is so rigid, (at least when you're starting out with a fresh pad), excess product will simply sling out and throw splatter everywhere.
I've done it myself and that's how I learned NOT to add too much product or practice the pad priming regimen. Now I watch others do it and try my best to caution them to both,
A: Don't prime pad when using the compound with the blue cutting pad.
B: Don't overuse product. And then when you do turn the polisher on, make sure the face of the pad is in direct contact with the paint and apply some firm pressure to TRAP the product between the pad and the paint and then get the polisher moving the product over the section you're going to buff when you first pull the trigger to get it spread out so it doesn't sling out.
Little tips but they will help you a lot.
You're dead-on accurate Chris... and Chris has used the Rupes system plenty since we brought Rupes on board...
Here's Chris aka Italian Guy...
Buffing on a 1955 Chevy Sedan Delivery here at Autogeek's Show Car Garage
Buffing on the North Miami Beach Police Department Mobil Command Center
Would the same hold for the yellow and white pads? There are times I'd like to polish out a small area as a touch up, but I feel like I'm wasting polish because I use so much to prime the pad and only a few drops for the polish area. I tend then to wait until there is a more area to do on mine or a friends car. Would a polish pad conditioner like the Wolfgang product be useful for this purpose?
Great job, Mike.
Why did you compound with the blue foam pad instead of going straight to a less aggressive pad and polish? Was this just for comparison?
Originally Posted by FivePoint.0
Great job, Mike.
Yep....
Just comparing for myself... thought I would share at the same time.
Last Post: 04-22-2020, 09:07 AM
Last Post: 06-25-2017, 12:12 AM
By Crispy in forum How to Articles
Last Post: 07-05-2016, 02:16 PM
By rah28 in forum RUPES BigFoot Oribital Polishers
Last Post: 12-22-2015, 02:20 AM
By DapperD in forum Wet-Sanding, Cutting & Buffing
Last Post: 05-21-2014, 10:16 AM
25 | 26 | 27 | 28 | 29 |
