Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Removing #1500 Sanding Marks with Rupes Bigfoot 21 Polisher
    Yesterday I created a thread to share the new 3M Flexible Hookit Sanding Sheets here,
    Dry Sanding & Wet Sanding with 3M's Flexible Abrasive Hookit Sheets
    As a part of sharing them I also sanded a small section on the hood of this hotrod Model A. I sanded just enough to capture a couple of shots showing what orange peel looks like as you start to knock off the tops of the hills to make them level with the valley.
    Here's a few pictures from the above thread...
    3M Flexible Abrasive Hookit Sheets
    These new flexible Hookit sheets us an anti-loading technology to help prevent the face of the paper from loading up with paint as fast and as easily as traditional wet/dry sandpaper.
    I sanded this section with about 10 back and forth passes and found the #1500 to cut incredibly fast.
    Here you can see the orange peel being removed as you look towards the bottom of the picture the orange peel is being removed leaving behind a very flat surface that after compounding and polishing will produce a smooth, high gloss finish with excellent Distinction of Image or DOI.
    Removing Sanding Marks
    "It's easy to sand paint... that's putting scratches into the paint. The tricky part is getting them 100% out"
    This morning I wanted to test out what it was going to take to remove the sanding marks to get an idea as to how hard the paint is. Normally I would finish out at #3000 or #5000 grit sanding marks to make the compounding step cooler, faster, easier and safer.
    Instead, I threw caution to the wind and just tried removing the #1500 grit sanding marks and to do this I used the Rupes Bigfoot 21 Polisher with the Rupes Zephir Gloss Coarse Gel Compound and Blue Foam Cutting Pad followed by the Rupes Keramik Gloss Fine Gel Polish and the Rupes matching Yellow Foam Polishing pad. I followed this with a quick application of Pinnacle XMT 180 Paste Wax machine applied using a Griot's Garage 3" Mini Polisher with a Rupes 4" polishing pad.
    This was just a test to a small section as I'm saving this car for this weekends detailing boot camp class. The Rupes Bigfoot 21 along with their compound and foam cutting pad remove 100% of the sanding marks after just a few passes.
    This first pictures will frame up the shot so you can see I worked in the same place I hand sanded...
    Now I've zoomed in and you can see the orange peel on the right side where I did not sand and how the paint starts to flatten out as you look to the right side of the picture.
    Below are some shots taken using different camera settings including one group of shots with the flash on.
    Orange Peel
    No Orange Peel but also no sanding marks and no holograms or haze...
    Orange Peel
    Orange Peel
    The sanding marks removed very easy without having to use a rotary buffer or wool pad which while it would likely work faster, the rotary buffer and the wool pad would have left holograms behind.
    Super Member Christopher.Brown's Avatar
    Jun 2013
    439
    Re: Removing #1500 Sanding Marks with Rupes Bigfoot 21 Polisher
    can definitely attest to removing 1500 sanding marks..
    using the rupes with a megs Mf cutting pad and M100 almost finishes down perfectly
    Quote Originally Posted by Christopher.Brown View Post
    I was surprised at how fast the sanding marks came out?
    My first though is soft paint.
    My second thought is uniform particle size on the sanding sheets as I didn't see any tracers at all.
    Of course, the Rupes compound and foam cutting pad are a very aggressive combo.
    At this time I'm planning on having my class use rotary buffers with wool pads though because there are a lot of curves on this hotrod and historically, the fastest way overall to sand and buff out the sanding marks out of an entire car is via a rotary buffer. It's also about hands-on training and practice, not just doing a car a certain way because you can.
    My class will get tons of hands-on time buffing out the 1965 Dodge Cornet with the Rupes system.
    Jun 2013
    Montreal, Quebec
    3,996
    I wish they had those in disk form for DA backplate. I have been searching for this all week. Finally found some but have to buy it in boxes of 100 disks ;( Would not be so bad if the box contained various grit sizes, but since I need 500, 800, 1500 and 3000 grit, that's 400 disks!
    Super Member hernandez.art13's Avatar
    Apr 2013
    6,958
    I was very surprised how easy the Rupes took out 1500 too
    Quote Originally Posted by Calendyr View Post
    What do you need such agressive discs for? Are you doing body work?
    Jun 2013
    Montreal, Quebec
    3,996
    Nah, just for headlight restoration.
    Well you really want 3" discs. Like this,
    I agree it would be handy to be able to purchase a mixed disc kit.
    Good topic for it's own thread.
    Apr 2013
    6,958
    This video is what gave me the idea of asking Michael Stoops if I could attempt removing 1500
    http://youtu.be/wfLdwFtAfaM
  10. #10
    Quote Originally Posted by hernandez.art13 View Post
    RUPES LHR 21E Random orbital polisher - YouTube
    Good video. One thing though, you can hear him pushing down pretty hard on the Rupes and it's designed to use light pressure and slow, even arm speed. Regardless, looks like he was getting the sanding marks out.
    Flat panels are pretty easy to work, curves will be more difficult.
  1. Makita BO6040 Removing Sanding Marks
    Last Post: 02-22-2021, 05:01 PM
  2. Removing water spots with Rupes Bigfoot 21 Orbital Polisher
    Last Post: 01-26-2019, 12:22 PM
  3. Replies: 11
    Last Post: 07-15-2018, 07:51 PM
  4. Vintage RUPES Milano Rotary Polisher - Type Vander - 1500 RPM
    By Mike Phillips in forum Car Detailing History - Vintage and antique car waxes and buffing tools
    Last Post: 08-24-2017, 01:58 PM
  5. How to use the Rupes Bigfoot Polisher - Detailing Class
    Last Post: 08-06-2015, 03:34 PM
