Re: White(ish) stains
The paint is by the way black metallic medium hard.
The polish machine is a copy of a Cyclo.
Has your car been kept under one of those car cover things at all?
If the answer is yes, then somehow (maybe the car cover is poorly designed and does not allow sufficient breathing...or....allowed moisture in) you have got water trapped IN your clear coat... And it hasn't been able to get out again..... I think the term coined is water entrapment....
Try the following:
1. Wipe affected area with rubbing alcohol (70, 90% what ever) and make sure the area is "wet" with the alcohol.
2. Alcohol (IPA only in this case) is a "drying agent" which is why it is used.
3. While wet, using a heat gun or even a hair dryer,start evenly heating the affected area, but do not allow the skin temperature of the painted surface to exceed 175 F.
4. Move the heat and air source, evenly over the affected area, starting at one edge, working your way across the area.
5. Observe if the "cloud" is going away.
6. A second application and heating may be required.
If this does not remove the entrapped moisture from the clear then try leaving the car out in the hot sun for a few days....
The bad news is, if this doesn't work, repainting is probably the only solution.
Hope this helps.
It is possible that the spots may actually be tiny divots (rock picks) and some left over product (wax, polish ETC.) is stuck in there.
Bill
Bill
I may be wrong but I don't think the OP is referring to the 'pitting' but rather the cloudy/milky type stains
it almost looks like old compound residue. Ive seen similar problems with repainted vehix. have you tried compounding it yet? When I see this type of cloudiness, Ive compounded and polished and rewaxed. can you feel it on surface?
Hello and thanks! I was regering to to milky kind of stains that looks like kind of spilled (and dry) milk.
The car has been in a garage when it was not used. One kan also see this miky stains appear as small spots (like waterdrops on a dusty paint)
I asumed someone had used industrial degreaser and damaged the paint.
The first thought in my head was that the former owner or the car sales companymhad missed some parts when the polished/Waxed the hood.
/Noobie
(From Sweden)
@jjj I cant feel any difference. I used rubbing, Then polished it, and used some sealer last. ...but my Cyclo copy is a really cheap one, and so not have so much power.
/Noobie
Gonna 'bump' this...hopefully more ideas will come forth.
Bill
What has he tried since? Clay,Polishes, Compounds?
I don't think the Mickey Mouse machine he is using matters (That Much)
I'll tune in and see what you guys have to say.
By Reno in forum Auto Detailing 101
Last Post: 06-01-2020, 12:26 PM
By Bufferyhype in forum Auto Detailing 101
Last Post: 08-12-2019, 04:20 PM
By KWOLDIE in forum Ask your detailing questions!
Last Post: 11-08-2016, 09:51 PM
By Rez90 in forum Ask your detailing questions!
Last Post: 09-05-2011, 07:05 AM
By M0nk3y in forum Show N' Shine
Last Post: 06-06-2011, 06:40 AM
