http://www.pressurewashersdirect.com...263/p6154.html
Quote from above site
Requires a minimum of 1500 PSI and 2 GPM•Maximum of 5000 PSI and 5.2 GPM
I have personally used my mtm on a 1700psi and 1.5 gpm unit as I already said so this says 2 gpm minimum and im sure it just produces there satisfactory level of foam at 2gpm I had no issues with 1700psi and 1.5gpm...
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government" Thomas Jefferson,
Re: Ok... Foam CANNONS, GPM or PSI ? for thicker foam
I have the electric Karcher (Model K5.740) and the AG cannon. It is rated at 2000 PSI and 1.4 gpm and I have enough suds to make a show (using Mr. Pink). I also use it with Dawn to strip LSP and even with Dawn I am producing a nice enough sud for dwell time.
Happy as a lark
[ame=http://www.youtube.com/watch?v=evFTeRxtEEo]The Perfct Wash with The Perfect Soap Garry Dean Wash Method Tampa, FL Infinite Use Detail Juice High end detailing Premium Custom Detailing traditional wash 2bm two bucket method proper car wash karcher pressure washer microfiber - YouTube[/video] Garry Dean use a foam cannon and a KARCHER
don't get the AG one, the MTM one does the same at the fraction of the price. And MTM will fit on Karcher.
AG one with a coupon + 20% and free shipping including the Karcher connector...... hmmmmm it was cheaper than the MTM hydro at the time.
I am sure we will see a nice discount for Easter
I just got all the stuff I needed to make my foam cannon work.
I have the:
AR Blue Clean AR383 1,900 PSI 1.5 gpm
Briggs and Stratton 1/4 x 25' Hose
Briggs and Stratton Gun
MTM Foam Cannon
Powerwasher 80006 Quick Connect Kit
^^^ Bought Online
1/4" Quick Connect tips set from Home Depot
Quick Connect Extension Wand
^^^ Bought local
You need all of this in order to make the AR Blue Clean work because of the hose and adapters that it comes with. Sure I could have paid $100 more and gotten a gas model but I have very little noise, no gas, no oil, no exhaust, and it stays ready to be used.
It all works great for its use. The extension wand makes it a bit of a pain since its so long but it works. I need to find an adapter or something to make it work without the wand. Its not super thick foam but I like it. I also don't have any basis of comparison so it seems to be good.
Soap used in this picture is Chemical Guys Honeydew.
Reason: Add a bit more.
you dont want to worry about water spots check out portable RV water softener units.
You my friend need one of these next...
http://www.cpsc.gov/cpscpub/prerel/prhtml11/11281.html
Sent from my SGH-T889 using AG Online
Originally Posted by HellaBroke
I need to rent a pressure washer to do the whole house and driveway.... one day....
I forgot to add that I used around 1oz of soap in that picture.
By DjbuddyPL in forum Auto Detailing 101
Last Post: 04-15-2016, 12:32 PM
By VW Drew in forum Auto Detailing 101
Last Post: 09-22-2015, 07:26 PM
By Toro1966 in forum Auto Detailing 101
Last Post: 09-18-2015, 07:20 PM
By pointillistic_practitioner in forum Auto Detailing 101
Last Post: 07-10-2012, 10:42 AM
By john b in forum Products Guides
Last Post: 03-24-2011, 12:03 PM
