Results 1 to 8 of 8
    Oct 2012
    173
    help with holograms ?
    I need some help after using groits best in show wax and there red pad i have holograms they so up in the sun like a sore thumb what did i do wrong?
    Apr 2008
    Clearwater, FL
    240
    Re: help with holograms ?
    Quote Originally Posted by dougsrt View Post
    Are you sure it's holograms and not just streaks?
    EDIT: Could it just be swirls that were there before and just more noticeable now that the paint is clean?
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    I seriously doubt any wax with a red finishing pad will leave any holograms. Just like g26 er said it was there before the finish work. BTW the only way to get rid of it is to compound and polish or perhaps polishing alone will do the trick. Waxing will not get rid of defects.
    Super Member Andr3wilson's Avatar
    May 2012
    Edmonton AB
    1,615
    What was your prep? did you polish before?
    Did you compound then wax?
    Are you using rotary or DA?
    Oct 2012
    173
    I did polish with GG machine polish 3&4 with my da could i have to much wax on the panel?
    Super Member mwoolfso's Avatar
    Jul 2011
    Long Island, NY
    2,592
    My gut tells me the polishing oils were not removed prior to waxing, then wound up inadvertently mixing with the wax when it was being applied. That said, it also cannot be confirmed the holograms were removed after polishing since the oils would mask the 'grams as well.
    If the holograms are due to product reasons, then apply some QD to the panels, wipe with some pressure and that should help. Over time the holograms will disappear as the LSP fades away. Another approach would be to do a 50/50 on a panel - one side leave alone or QD it. The other side, wash, clay lightly and quickly, QD, IPA, then apply wax. Compare both sides for holograms. If your fully treated side still shows holograms then it was your polishing process and/or technique that needs some fine tuning before you re-polish the whole car.
    Super Member umi000's Avatar
    Jan 2011
    Manila, Philippines
    1,110
    You might be seeing carnauba sweating - do the "holograms" shift if you wipe with an MF and qd?
    Francis
    Oct 2012
    173
    Sounds like the plan i will try the 50/50 and put the car out in the sun and have a look i'll post the results if the sun ever comes out lol thanks everyone for the info!!!
  1. Holograms ?
    By chuckk in forum Auto Detailing 101
    Last Post: 01-03-2016, 05:18 AM
  2. Help with holograms?
    By MstrJosh in forum Auto Detailing 101
    Last Post: 07-25-2015, 12:07 AM
  3. Now that's some holograms
    By Nate3420 in forum Auto Detailing 101
    Last Post: 06-03-2013, 07:08 PM
  4. Holograms!!
    By 93fox in forum Ask your detailing questions!
    Last Post: 02-07-2011, 10:20 AM
  5. Holograms in my BMW X5
    By Goodloe3 in forum Wet-Sanding, Cutting & Buffing
    Last Post: 12-20-2010, 12:38 AM
